Blew main fuse on gem 350 one under the plug,put in spare now 8 amp[ fuse in side keeps blowing.what going on?
I really need gems plzz give me c o c hack
Posted on Oct 16, 2014
    Genius:
  • 1,175 Answers
One or both of the power output sections has a failed part/parts
It will need a tech to repair
Posted on Aug 03, 2009
1998 plymouth breeze hazard flasher fuse keeps blowing
check the hazard switch pull the switch and put a volt meter on the connections with wiring connected to switch if it don't respond or just gives you a L.O your switch is bad and shorting out could happen just from being used a lot or something internal broke switch for that shouldn't be all but 50$ or just go to a parts/scrap yard
Jan 22, 2014 | 1998 Plymouth Breeze
I have a 2005 cavilier..it keeps blowing the main 30amp fuse when the ac is turned on..any help
you need to inspect all AC WIRING, to find the SHORT, thats causing the fuse to blow ! donot put another fuse in until you locate the shorted condition, ( bad connection, frayed wire, bare wire touching metal along this circuit, you might have a bad switch, your ac has two switches under hood, one @ high pressure side and one @ low pressure side. and your main control switch, check all wires & connections
Mar 11, 2013 | 1991 Chevrolet Cavalier
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
2005 Saturn Vue Repetitive Ignition Fuse Failure
I think there is a short in the system, possibly happened while replacing the main brain.
Jun 19, 2012 | 2005 Saturn VUE
Main 30 amp fuse keeps blowing when i plug the 4 wire fuse top back on after replacing 30 amp fuse. any suggestions
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
keep blowing the 30 amp fuse
main fuse keeps blowing
Honda Shadow VT1100 Owner Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda shadow vt1100 Owners Workshop Manual
Jul 14, 2017 | 2003 Honda VT 1100 C Shadow Spirit
Hooked up spare battery to the wrong terminals now have no power at all lights still work but no dash lights? what could it be is there a fuse that might have blown or something worse?
Under the hood is a fuse box. In this box is going to be a large fuse (between 60 and 100 amps usually) and it may be labeled 'main', 'alt', or 'batt'. This is the fuse that runs from the battery to the main power of the vehicle. When you hook a battery up like that it blows this main fuse. You'll need to replace that and any other fuses it blew out.
May 04, 2011 | 1994 Mazda MPV
Main ignition fuse keeps blowing out on my 2000 Kia Sportage
Possibly a bad ignition switch unplug the harness under the dash follow it from the ignition to the plug (about 8" from ign) unplug it put a fuse in and see if it blows.
Hope this helps!
Oct 23, 2009 | 2000 Kia Sportage
125 v 4 amp fuse keeps blowing
if you plugged a 125 volt tv in to a 220 volt outlet you more than likely fried alof of the componets in the tv. Putting a bigger fuse in there is only going to increase the risk of it catching on fire so i would not recomend that. you might replace the power supply and cross your fingers and hope that nothing else cooked when the 220 volts hit it
Mar 14, 2009 | Televison & Video
Klipsch sub 10 keeps blowing fuses
More than likely the power supply switching transistors have fried. Also check the large caps in the primary side of the power supply. If you don't know what your are doing do not attempt to fix the power supply.. very dangerous voltages involved !!! Send it to Klipsch for repair or purchase a Bash replacement panel http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-750
Jan 17, 2009 | Gem Sound SUB-650M Speaker
121 people viewed this question
 Grubhead
Grubhead
