Question about Maytag Washing Machines
Maytag Dependable Care washer loud rattle noise during spin cycle
I had service two months ago on my washer becuase it was vibrating/shaking volently during the spin cycle. The tech found the snubbers dry causing the drum to be tight. He lubricated snubber as best as poissible and leveledlegs. In my reading, I have learned snubbers should not be lubricated, but should use cornstarch??? The floor is weak - it flexes. It is plywood under a no-wax type floor.
He returned last week and now says the break bearings needs replacing - he tells me the brake bearing sits on top of the transmission. If I chose to replace this, i should also replace the snubber assembly. Price...$450.00!
My question - does this sound like the right diagnosis?? I hate to call another tech in and have to pay the 90.00 for him to walk in the door and get a second opinion. Is it likely this tech is right considering the age of the machine? He said if I can live with the rattling noise during the spin cycle,it won't hurt the machine and to just replace it when it dies.
This machine is only six years old, it is the Maytag Dependable Care Quiet Plus. I am very disappointed on the number of service calls on this machine over the years. I chose Maytag for the life expectancy - figuring at least ten years. Maybe that is too optimistic these days.
  • 213 Answers
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Posted on Nov 20, 2007
SOURCE: we are installing the snubber
iT TURNED OUT WE HAD NOT BEEN INFORMED ABOUT THE TILTING OF THE MACHINE WHEN IT WENT OUT OF BALANCE. WE ACTUALLY DIND'T NEED TO CHANGE THE SNUBBER. IT WAS SHOWING SOME SIGNS OF WEAR, SO MY HUSBAND DID CHANGE IT, AND WE NEVER DID FIGURE WHERE THE DIMPLES ARE, BUT THE MACHINE IS WORKING LIKE NEW FOR A MINIMAL COST TO US.
Posted on Aug 08, 2008
SOURCE: rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Nov 12, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
SOURCE: Frigidaire front load washer model GLTF1670ASO
Check the shocks on the bottom of the drum. I had the same problem and had to replace the shocks because they were broken in half.
Posted on Dec 07, 2008
Loud vibrating washer
What is the model number of the unit?
Mar 03, 2014 | Kenmore HE2 Plus Front Load Washer
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Washing Machines
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle is very loud but works well
my neptune was so loud it sounded like it was taking off, it turned out to be the bearing in the drum, the repair man wanted $1200. to fix it. i called maytag and this part has a lifetime warranty and they sent it to me in 2 days.
Feb 11, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Dec 06, 2008 | Maytag Neptune Washer
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
338 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
