Lands Phones Logo
I
Ignatius Chimfwembe Posted on Jul 17, 2018
How do i configure the panasonic kx-tes824 to allow outgoing calls?have done all the settings using the console software from my laptop and everything is working fine but i cant call outside lines.
Avura Samuel
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 04, 2020
Avura Samuel
Contributor
Level 1:
Answers
Questions
0
Helped
2044
Points
How do I get the software for programming 824 and tda 100
omonat at engineer dotcom
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Sep 02, 2018
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
11
Questions
0
Helped
4015
Points
25
Hello, How many CO Lines do you have connected to your KX-TES824 Phone system?. The ports that are not connected need to be deactivated. Go to CO -> Detail and uncheck the ports that don't have lines plugged in and click apply or OK
4 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Oct 09, 2009
SOURCE: Two phonelines no longer accessible. Using
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Nov 21, 2010
SOURCE: Hi i have a panasonic KX-TES824 installed with 2
A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
Carl
MiroM
  • 4 Answers
  • Posted on Feb 10, 2011
SOURCE: Panasonic KX TES824 Using KXTE console
there are two conditions You have to keep:
- call FWD to CO has to be allowed in reg 607 during system programming.
- CO call has to come to extension in DIL1:1 mode.
Mirro
Anonymous
  • Posted on Mar 16, 2011
SOURCE: how to configure panasonic exchange
we have a panasonic tem 824, where we connected 8 analog trunks, the problem is we cant hear the incoming calls if somebody call from their mobile.
can somebody help me!
Can the Panasonic KX-T7667 phone work with the Panasonic KX-TES824 PBX?
Yes, the Panasonic KX-T7667 phone and the Panasonic KX-TES824 PBX are compatible.
The KX-TES824 should be able to accommodate different handsets because it is made to work with a variety of Panasonic phones, including the KX-T7667 model.
You must connect the KX-T7667 phone to an available extension port on the PBX and configure it with the proper parameters using the PBX programming software or a web interface in order to add the phone to your current PBX system.
It's vital to keep in mind that the KX-T7667 is a proprietary phone made just for Panasonic PBX systems and might not work with other phone systems or third-party hardware.
How to assign a CO to a specific extension for outgoing call on panasonic KX-TES824?
WELL.....
Is this on a multi line phone?
Is this going to be the only CO line on a particular set?
Is it part of a trunk group?
Is this to be accessed by dialing 9?
Flex out dialing may be what you are asking about but I really can't tell from your question.
To set incomming calls to ring only on extension 101 kx-tes824
This programming is done at the KSU by using the Programmer's tool.
To enable caller ID phone tes824 through 7730
Hi
I am using Caller ID software and I want to configure PBX to send the log call to our program when an incoming call, then when I answer the call and another after the end call, is there a way to define the PBX to do that
note : PBX now send call log only after the end call.
1helpful
I have a panasonic KX-TES824 Advance hybrid system machine. i want to how to check in and out calls from co lines.
On the side of the cabinet is a DB-9 serial port connector. If you get a PC or printer attached to the port and turn on SMDR, it will capture and print all activity in the system. There are no set log files for outgoing calls otherwise, but there is a limited set of incoming call logs where you can see the last 300 calls. It's in the programming manual for your system.
Carl
2answers
How to configure panasonic exchange Model KX-TEM 824 to work with telemanager call tracking software using telephone KX-T7730
It's pretty straightforward. The DB-9 connector on the cabinet is turned on by default for incoming and outgoing calls, so all you have to do is connect your serial port to the Panasonic serial port at 9600,n,8,1 (default). In the Maintenance console, tab 1.7 adjusts the output. How you set up the software is part of the manufacturer's instructions. The Telemanager software on my search engine was designed for the NANP only.
Carl
1helpful
Panasonic KX TES824 Using KXTE console I am trying to forward extension 201(outside calls directed to 201) to an outside number. I have set in feature settings fwd to co and then put a 9 and number in...
Mirro
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
