Zanussi zwf123w goes from wash to drain
Zanussi zwf123w seems alright when its programmed but when it starts it goes to the led wash, fills up and then ges straight to the led drain, missing out everything else. The water goes in pre wash drawer when it fills the drum and then empties straight after without any spin. It is capible of spinning as we went to spin using the reset button but when programming wash it jut won't do anything but fill and drain.
  • 24 Answers
Check heater
Posted on Aug 05, 2009
My machine fills with water it drains it spins there seem to be a problem with the programmer
You must recheck with another program and if the cycle goes on without the correct sequence then the program controller unit is faulty.
make sure that the connections are firm, the motor is manually moving and the water level sensor- pressure switch is in order.
consider the cost of a new program controller and confirm the fault, before you buy.
Apr 01, 2011 | Zanussi ZJ1217 Front Load Washer
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Zanussi fj1254w washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 04, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
