Question about Remote Controls
Remote Code ?????
Looking for the remote code for a swisstec tv. S15/5
Swisstec / Sky Media UK Ltd
please help
SOURCE: sky+remote code for my lg tv
hi.ive got a rev 8 sky plus remote and a LG 42PC56 42INCH TV and the code is 0206.hope this helps some people
Posted on Jul 29, 2008
SOURCE: Sky remote codes
Posted on Aug 27, 2008
Herb Box
  • 68 Answers
SOURCE: my sky remote wont control the volume on my tv
These are all the Sky Remote codes I know of for Toshiba, 0271 0746 0063 0064 0223 0536 0581 1065 1184 1293 1684 0037 1317 1536 0530 0678 1732 0117 0269 1973.
Posted on Dec 19, 2008
SOURCE: SKY remote control programming
I used 0081 for the KENMARK LVD160 and it worked straightaway. This was for a REV 6 - SKY remote.
Posted on Mar 14, 2009
SOURCE: Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Posted on Apr 23, 2009
SOURCE: i have a 32inch mirai tv but my sky remote control
Try using 0000 code
Posted on Jul 21, 2009
0 characters
1 Points
Can you tell me the code for a veitech tv . I cannot find the code to programme the remote hope you can help ?
can you till the code 4 veltech tv two operate sky remote > TV
Question - can you till the code 4 veltech tv two operate sky remote - 2H. ... if you will rate me in a positive fashion before you close this page, the system will ...
Sky Digibox TV remote control codes for your television
Jump to How to get inside remote - If you warm the remote with a hair dryer, the plastic becomes more ... Please tell me if the link no longer works.
Jan 20, 2016 | Remote Controls
Sky remote control code for samsung ps43e45/49 tv
The code you are looking for is 1340. I have the same TV and my sky volume hasnt worked since I bought it, (9 months ago).. After spending an age on the SKY forum with no luck, I simply googled (Sky remote codes) and clicked on the 1st site, it's then Samsung 6000 series.... It told me the correct code and gave me clear instructions...... I hope this helps someone else.
Aug 17, 2012 | Samsung TV Remote Control
I need a code for a ue40d5oo0
on ur sky remote,,
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Enter the digit code - 0646
  5. Press the Select button to store
  6. then press tv and check the volume if it works on sky remote..
    if u still cant do it go to
May 05, 2012 | Samsung Remote Controls
Need the code for a technika tv
You can check codes for your remote control here:
I tried to get codes for a Technika TV, but according to their code finder, your remote will only work with Technika devices of the following type:
Cable Converter
DVD Player/Recorder
Satellite Receiver
I will try some other sources to see if there are any codes for Technika TVs.
Oct 18, 2010 | One For All URC 7740 Remote Control
Sky remote code for tv model JO47 Baird
These are your codes,0117,137,221,371,218,220,236,100...Here is a link for directions, hope this helps..
Mar 31, 2010 | Remote Controls
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Remote Controls
Sky remote
Try this maybe it will help
Feb 01, 2009 | Microsoft Windows XP Media Center Edition...
No remote for Swisstec T.V.
Hi rhami,
The only brand of universal remote I know of that has a code for Swisstec brand TVs is the Integra - the code is 0880.
The other option is to order a replacement remote for your model TV. carries remotes for a wide variety of Swisstec TVs (note that does *not* offer these since Swisstec is British).
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Remote Controls
Proteam large button remote code
All of the universal codes are listed on the UK website for their helpline. If the code listed does not work, its likely that the remote control is too old and was manufactured long before the TV.
Nov 19, 2008 | Big Button TV Universal Remote
Sky remote code
codes for bush are
codes for bush uk are
hope this helps
Dec 08, 2007 | Directed 434MHZ Remote Control
Remote Controls Logo
29 people viewed this question
Top Remote Controls Experts
Are you a Remote Control Expert? Answer questions, earn points and help others
