Question about Dometic Rooftop RV Air Conditioner
Change starter capacitor ac work work
We changed the starter capacitor and now we have no 12 volts to the comfort control center. Ac won't work at all. We have a 2005 36re3 mobile suite witth duro therm ac units.
Thanks
Kendra
  • lilbear60 Aug 03, 2009
    it is a 36ft mobile suite 5th wheel. We have two units neither one works now. We don't have 12 volt dc going to the ac power module board on the front unit, nor do we have 12 volt dc power to the comfort control. we have checked fuse panel and front unit 3 amp fuse. Both fuse are good. There is power at the fuse panel for that curcuit, which is suppose to feed the front ac unit. Check 6 pin conector black and red wires, do not have 12 volt dc.
  • Mike Butler
    Mike Butler May 11, 2010
    Is this a 36 ft motorhome?
  • Dometic Master
  • 6,674 Answers
What about furnace is it working at all?
Posted on Aug 03, 2009
How do I fix broken JBL flip will not turn on?
You smoked off the regulator , a transformer is for AC voltage change like say a step up or step down and the trxfmer just shot AC voltage to where DC should have been. The bridge rectifier is what changes the AC to DC not a transformer . If you have soldering skills you can replace it on the board , it could be you just cooked off a diode (1 of 4 to make bridge) . Hope this helps
Apr 02, 2015 | JBL Audio Players & Recorders
Ihave 12 volts going into the ac but no power at the comfort control,
There is/are fuse/s in the Comfort Control. It depends on which model. There are also fuses in the control box in the AC behind a cover in some models. Heat Pumps have fuses on their control board on the outside, under the plastic cover.
Mar 22, 2015 | Dometic Heating & Cooling
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
Won t start
Check battery must fully charged, check starter fuse and relay Check 12 volt wire from ignition switch to starter relay in the fuse box ,then check 12 volt wire from starter relay to starter motor solenoid if if it's everything is ok then change the starter.
Oct 20, 2013 | Buick Lucerne Cars & Trucks
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
Cp9430r
Fixed Hunter ceiling fan with remote light pin out wiring 9 wire plug search words
Hunter Ceiling Fan with remote, fails to turn on light, fails to turn on fan..remote receiver is Cp9430r
1) Test your remote, Hunter uses Radio Frequency remote, point RF remote one inch from antenna of working AM radio, press each button on remote, each button will produce static sound from AM radio, if no sound..check battery wiring or solder connection on loop antenna of remote. If no sound on one or more buttons, disassemble and wash key pad with dish soap, rinse and fan dry, retest. If still one button no work apply graphite paint to button to rebuild conductivity of button.
2) Cp9430r receiver is below fan and above light. Remove light assembly, check receiver dip switches, mine was #5 On 1~4 Off, check remote control dip switches in 9v battery compartment also set #5 On 1~4 Off, new 9v battery still no Fan reversal "click" sound heard coming from the large Blue fan reversal relay located inside the Cp9430 receiver. All other buttons control transistors and will make no sound even if they are working.
3) Disassemble / unplug 9 wire plug from Cp9430r receiver, place receiver on wooden table, 9 wire plug has two empty pin squares, one empty in the center, the other empty we will call #1 ..counting clockwise #2,#3...#4,#5..#6,#7and finally top center next to empty #1 is #8. Now #8 is 110v hot/black ...& #4 neutral/white.
4) Shock Danger..carefully apply ac volts to pins #8,#4 use tape if needed, locate quad operational amplifier i call it radio receiver chip HA17324 on board, google HA17324 Datasheet, locate leg #14 it is across from leg #1. Locate small yellow ceramic capacitor very near leg #14, use capacitor's neg as neg for voltmeter, test volts at #1,#7,#8 and #14. My #1 was 3.1v, #7 3.2v, #8 3.25v and #14 .01v ...why #14 so low? I monitored each leg while pressing remote control buttons...no changes. **Desperate, I sparked (1/2 second or less) #14 with 3.14v from positive leg of yellow capacitor** and retested all legs, no change except now #14 rests at .02v and jumps to 2.5v~2.8v when any button on the remote is pressed then rests at .02v. Now Lights work, Fan speeds work, Reverse rotation Works :-)
Pin Out on 9 wire plug, #1 Empty pin, #2 Alternates w up/down fan rotation, #3 goes to 5uf fan capacitor other side of cap goes to white/neutral AC Line, #4 AC Line neutral, #5 goes to Triac? speeds? , #6 Alternates up/down fan rotation goes to up/dn blue relay, #7 goes to up/dn blue relay looks to be AC hot looking for fan probably paired with #3 changing sides at up/dn blue relay, #8 AC Line hot in. Why did **sparking** work, smarter people might know, i think a small spark got stuck in the chip and sparking helped the chip release it out. No electrical education, novice. Jer. 51 8,9 and 11
Feb 24, 2012 | Hunter (25417) Ceiling Fan
I have a old tow motor w/ a wisconsin air cooled engine . I'm looking to change the 6 volt system to 12 volt system. looking for a basic 12 volt wiring diagram for GM alt. and wisconsin parts?
to change the points to electronic you will need to get the manufacturer of the distributor and contact them for a compatible electronic kit to replace the points or replacement distributor
to fit an alternator , get one with an internal voltage regulator ( talk with an auto electrician for the best unit --it is not necessary to go big amperage units so one about 35-60 amps will suffice and cheaper as well)
wiring will be the same as will fuses (neither volt sensitive)
gauges will have to be changed to 12 volt units
bulbs changed from 6 volt to 12 bulbs and switches will be the same as they are no volt sensitive
basically the same circuit can be used and the only place to be careful is the alternator wire to the battery and the charge light or volt gauge ( auto electrician can advise here )
starter motor will have to be changed to 12 volts and you will again have to get the replacement unit from an auto electrician as the bendix pitch , movement and mounting neck will be critical
wisconsin did not make electrical components but used off the shelf companies such as delco remy, lucas , bosch, ac etc for the accessories to the engine
it is an interesting project so collect as much information from auto electricians and web sites to help you
Jun 06, 2017 | Cars & Trucks
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
MISSPLACED AC POWER SUPLY FOR "MY BOOK" 250 GB USB.
THE ANSWER TO MY QUESTION WAS FOUND OUT BY MYSELF BY VISITING A REPAIR / SERVICE DEPARTMENT AND MAKING ENQUIRIES CONCERNING THE DC OUTPUT OF THE AC ADAPTER ASSOCIATED WITH THE WESTERN DIGITAL, MY BOOK 250GB USB. tHE VOLTAGES ARE THESE. : - AC INPUT = 100 - 240 VOLTS 50/60 HZ
DC OUTPUT = 12 VOLTS ( REGULATED ) 2 - 0 A
CENTER PIN OF 12 VOLT DC INPUT PLUG IS " POSITIVE "
THANK YOU FOR THE SPACE TO ASK MY QUESTION.
Feb 18, 2009 | Western Digital My Book Essential Edition...
Dometic Rooftop RV Air Conditioner Logo
311 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
