Question about Acer Aspire™ T180 PC Desktop
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
Has anyone used acer BIOS update vR01-B1 for the issue I asked about previously? The issue I refer to is the pc does not boot with all 4 RAM slots filled. It boot and runs great with any 3 slots occupied with any RAM configuration. Has DDR2-5300 (667) RAM. New RAM is same speed, 1gb X 2 modules. Memtest confirms modules are all good. Came with pc2-5300 512mb x 2, trying to add 2 x 1gb pc2-5300 to the mix. Total 3gb. System specs say it supports 4gb total RAM.
Thanks for any assistance.
ww
  • Kim Jensen Nov 04, 2008
    I've recently upgraded my Acer Aspire T180 with DDR2-800 2 x 1GB and with CPU - AMD Athlon64 x2 Dual Core 5200+ 2.6GHZ.
    It was fine for the first week but now it keeps freezing after being on for about 20 mins. I can't even use CTRL+ALT+DEL.
    Contacted the shop I purchased them from and they have suggested updating the BIOS. Contacted Acer but the were no help and basically told me I shouldn't do it. They didn't even give me this link -
    http://www.acerpanam.com/synapse/forms/p...
    Any ideas of what I should do?
  • ken w green
    ken w green Nov 03, 2012
    wat does dmi pool data then FWYSKis compressed then press ctrl alt del to restart an it comes bact to the message so wta is wrong with computer
I had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Posted on Nov 30, 2007
  • DaveMM123 Apr 15, 2011
    I was having the same problem. staggered the cards in all four slots ait seems to work fine.
  • 4 Answers
Need to install stagerd 1g 512 1g 512 in that order your will see 3gb how ever as soon as you get over one gig vista will use a full gig
Posted on Aug 12, 2009
Alternating (staggering as per above suggestion) the 1GB and 0.5GB modules worked for me. However, it did not work with 4 Kingston KVR 800mb 1GB modules (2 2G kits)..
Posted on May 17, 2008
I have the same problem most of you do I am pretty sure it is the bios verson R0-B1. Acer says its the upgrade for the T180 but if you look at the description on the site it says its for XP. There is no place in advanced chip set in is bios version to change from single to dual this is also why I believe it is a XP bios version. I had no ram issues until I installed VR0-B1 now I can only use two ram slots adding any more in any configuration and my OS will not boot. Good luck getting any help from Acer. I am pretty sure that if I can just get a copy of the original Bios (which by the way is like finding a needle in a hay stack, no one seems to know) my system would recognize the other slots, but alas cant get any help. It looks like I am stuck with 2 gigs 1gig X2. I might try to put two 2 gig sticks in and see if I can get the 4 even though it will not work as well as four 1 gig sticks would. If anyone know the original bios version please let me know my system is the T180 4400+ dual core amd athlon .
Posted on Apr 16, 2008
If u tryed using 4x512 mb or 4x1gb if its not worked try to update u r bios also check maximum cappacity of slots(i think u r allready checked out )and try to ugrade u r bios by visiting
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=3889&formid=3394&website=AcerPanAm.com/us&siteid=7293&words=all&keywords=&areaid=7
Posted on Nov 25, 2007
Acer Aspire T180 - Very Slow Boot to Post Screen
You can run drive diagnostics to test RAM and hard drive, but I would guess that it's a peripheral of some type (I wouldn't think it would be a hard drive or memory problem since your PC runs well in windows). Since the system will eventually time-out trying to initialize a device, it would explain your symptoms. I would unplug your CD drives one at a time (with the system off) and reboot. If you have an onboard card reader, try that next. Printers, headphones, webcams, or any other USB devices can also cause problems.
Once you isolate the offending device, you can try to update your BIOS since some bios updates will address this type of issue. I am not sure if Acer offers BIOS updates, but you could always ask their tech support.
Regardless of the device, it could be an incompatible or failing device. Printers always seem to have updated drivers, so you could check with the manufacturer regarding that.
Otherwise, I would replace the device and test again.
Good Luck!
Dec 28, 2011 | Acer Aspire Computers & Internet
Generic memory problem for all Acer PC Desktops
In most cases will only see the RAM that is available AFTER the windows allocation size. If windows allocate 1 GB to itself for its processes etc. You will only see 3 GB available for viewing.
Sep 17, 2009 | Acer Veriton 7700G PC Desktop
When trying to boot acer aspire T180 computer only getting the acer screen and no response from the keyboard either help please help
Hello jamesruss590, this is material issues so first try to change your memory RAM and boot the pc again try this and answer me.
Jun 11, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire 9410 Won't work with two memory slots filled
As you mentioned that you want to use Maximum memory that is supported by 9410, I would like to tell you that you have 32 bit processor in your notebook as its not always advisable to use 4 GB RAM with 32 bit processor as we have seen lots of compatibility issues.Infact in 32 bit processor windows will typically report only 3.2 GB due to a limitation of windows itself.
Mar 25, 2009 | Acer Aspire 9410-4317 Notebook
Can not upgade memory from 2G to 4G
have you checked the frequency of the new ram you are using if its not of the same type and of same frequency as of the another one your system wont boot
Sep 14, 2008 | Acer Aspire™ T180 PC Desktop
Memory installation
bev,
all the DIM's must be of same type and same size to work, otherwise it creates problem, like no boot, boot with lowest memory etc.
There is no problem in your PC, its technical issue you can not use two ore more different type RAM at the same time in a motherborad.
Thanks
Iqbal
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Ram memory conflict
adjust memory timings inbios and check u sitted it correctly.
Apr 04, 2008 | Acer Aspire™ T180 PC Desktop
Increase Memory.
no u dont need look @ the bios>if u insert it properly that should display it if it is not then teh card is bad>or the slot on the board if the solt works with the other card then there is no issue with the slot so replace it rate me solved if its help full thx
Nov 05, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
4,693 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
