Question about RCA 27R411T 27" TV
RCA 27R411T 27 high piched squeal
RCA 27r411t chassis that emits a high pitch sound as soon as it is plugged into the ac power outlet. The set will not power on.
Have the same problem? Click Here
How do I setup a RCA 27R411T 27" TV set to a clear tv antenna?
The antenna connects to the ANTENNA connector on the rear of the TV.
Feb 10, 2017 | RCA Televison & Video
It has sound but no video
If it's the TV on the picture, It would be cheaper to by a new set. I repair TV's and old school picture tubes are very hard to find and not worth the time to replace. Flat screens show better and use a 3rd of the energy.
Feb 28, 2015 | RCA 27R411T 27" TV
Hooking my Dishnet work cable to TV modele 27R411T
tuner might be out, try video 1 with the rca cables
Sep 03, 2012 | RCA 27R411T 27" TV
The parental control has been set on my RCA television and I dont have the password.
Try this turn tv off, press and hold + on the volume for about 5 seconds, then re-enter a code. ..hope this helps...
Mar 16, 2010 | RCA 27R411T 27" TV
Can not get the DVD player to display on the screen of my RCA 27R411T. The TV is on and the DVD player is on.
Are the A/V cords plugged in correctly? Know that the wires and jacks are color coded and OUT should always go to IN and vice versa. Also check the cords and jacks for damage. This may solve your problem, let me know if it dosen't and I may have other solutions for you. Good luck to you!
Jan 03, 2010 | RCA 27R411T 27" TV
No picture no sound just a whistling noise
maybe the flyback transformer or horizontal output ic
Jun 01, 2009 | RCA 27R411T 27" TV
Try replacing the eprom. If that somehow became corrupted due to HV surge or otherwise, you would have this symtom. The eprom contains information that basacally tells the HV circuit to turn on.
Apr 06, 2009 | RCA 27R411T 27" TV
Can't hook up DVD player to RCA TV?
please re chech ur input cables
Dec 25, 2008 | RCA 27R411T 27" TV
RCA 27R411T 27" TV Logo
53 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
