Question about Refrigerators
I have water dripping inside the fridge. the pan
I have water dripping inside the fridge. the pan underneath the fridge is empty, I wonder if the drain is clogged. I am defrosting the fridge completely, umplugged and doors open, hoping it's ice but it might be something else. Dust or food, how can I clear this?
    President:
  • 2,559 Answers
You can clear the drain by removing the bottom drawer , you will see the drain hole,you can use a vacuum to **** it out or a flexible wire to push through it.
Posted on Aug 02, 2009
We have water underneath our freezer and inside on the bottom shelf
You probably have a clogged drain line. Look for a drip pan at the bottom of the fridge; it should have a hose that drains into it. Thaw out the fridge like you did before, but this time use an air compressor, bicycle pump, or whatever and try to force air back up that hose to clear the clog.
Feb 16, 2015 | KitchenAid Superba KSRG25FK Side by Side...
Samsung refridgerator freezes due to clogged drain line.
I would look for bad door gaskets. Sounds crazy but if you have bad gaskets, you will let in more moist air and the freezer will freeze up faster. If the fridge is freezing up I would look at the slide from the freezer to the fridge and see if it is stuck open. During the defrost cycle the unit should drain and fill the drain pan, but the normal operation of the compresser should be able to evaporate the water with ease. Look at the door gaskets and the vent. Good luck
Sep 08, 2012 | Samsung RS2556 Side by Side Refrigerator
Why do i keep getting a puddle of water in the bottom of my frige? The water must be coming from the top because each day, there is water on top of the food containers all the way down to the bottom.
Sounds like you have a defrost drain issue. Often times these get clogged, and the back flow water drips into the fridge, usually the culprit on a GE is a clogged drain diverter, located on the outside back of the unit. Remove the tube by bending and pulling away from the diverter while holding the diverter firmly in place. Then turn the diverter one quater turn clockwise and it should pull down and away from the appliance. Clean this diverter out thoroughly, as it is likely full of gunk. However, on some older model GE top mounts, ive seen the drain pan underneath the evaporator coil inside the freezer with a small rust hole, and the water drips through this hole instead of the intended drain hole, the water then misses the tubing, and drips into the fridge. this drain pan will then have to be replaced.
Dec 10, 2010 | GE Refrigerators
I have a Frigidaire model number FRT18G4AWA refrigerator that leaks water from the top of the refrigerator part and has trouble keeping cold.
Make Sure Your Fridge is Properly Sealed
One of the most common causes of a "leaking" fridge isn't a leak at all. It's the direct result of your fridge not sealing properly, and as a result running overtime to keep things cool. A fridge that runs excessively will build up extra condensation on the coils, which in turn can lead to the pool of water on the floor that's causing alarm. Check the rubber door seals on your fridge and freezer to make sure you're getting a proper seal. If you find a problem, wash the seals with warm water and soap and apply a thin film of lubricant (petroleum jelly works best). If this doesn't solve your problem, you may need to replace the gaskets. Also, check the adjustable legs on your fridge and make sure the fridge tilts a little to the rear. If it's leaning even a little bit forward, a proper door seal can be compromised.
Check the Drain Pan
Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
Check the Defrost Drain
If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Check Your Ice Maker for Leaks
If none of these other quick fixes solve your problem, check your icemaker for leaks. It's a bit unusual, but sometimes the water line to the icemaker fails or comes loose, letting water into your freezer. Try tightening all connections, and if necessary, replacing the line that feeds the icemaker.
Hope this helpout....
Aug 13, 2010 | Refrigerators
Defrosting water flows backward inside the fridge.
Defrost water should not be visible inside the refrigerator. This water should drain from the evaporator coil to a catch basin in the rear of the unit (behind the inside liner of the refrigerator). The water then should drain into a plastic tube that carries it to a pan underneath the refrigerator. Heat from the coils and compressor then evaporates the water.
Something in this drain system is blocked.
Oct 18, 2009 | Refrigerators
Where is drip pan on profile side-by-side
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket.
Sep 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
May 29, 2009 | GE Refrigerators
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Jan 02, 2007 | GE GTS12BBPLCC Top Freezer Refrigerator
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
