SOURCE: Putting a new door on my Sony CDP CX300
u must remove the broken old door carefully by removing the rubber belt which is connected to the dc motor and bear by there be a white colour plastic which holds the door u must remove that and then u must put replacement & once again u must connect those all properly so it s difficult... just visit technician....
SOURCE: disc(s) jammed in sony 5-disc player--eject won't work
There are 6 or 7 phillips head screws that keep the top on; remove them and pop the top. This will give you access to all CD's. Remove them all, then plug the unit back in and press the open close button and check for normal operation. If it still wont open, it's broken a gear and needs to be serviced. You may consider replacement of the unit if inoperative, the replacement model is priced at $129.00 and a repair would probably cost the same if not more. If you need further help, post a comment and I can help you further.
SOURCE: My Sony CDP-C910 cycles through CDs, never playing
when its cycled thru them .,does it stop?does it show them on the screen with a lit circle?are they normal cds.can you select one cd to play?hold the eject button in for about 5 seconds,see if that resets it
Testimonial: "Very kind to have answered so promptly and provide insight."
SOURCE: My Sony MegaStorage CDP-CX455 400 Disc changer
Pretty much the only thing you can try at home is cleaning the laser lens, if the cleaner works then remember to use it now and again.
If the CD lens cleaner does not work the take it to the nearest sony tech/dealer for repair. Multi CD systems are very complicated and need specialist attention.
Hope this helps
Thanks for using FixYa
SOURCE: jammed door sony CD changer CDP C365
I'm Sony tech and can help you to fix this cd player.
CDP-C365 is 1994 cd player, mostly loading belt got cut/ broken in 16 years service, take off top cover and inspect loading belt, replace it if found cut/ broken.
Next possibility is loading mechanism got misaligned for any worn out gear that needs visual check, let me know if you need part number info about broken parts.
Thanks.
