Question about iLO Televison & Video
Are all ilo tvs analog - iLO Televison & Video
Who makes these TV.
made for wallmart by ILO
ILO TVs made in China. A few brand have been connected with iLo, are Funai, Orion, Tatung
ILO customer service number is 800-289-0980 or 1-800-939-0605
ILO TV Codes. 11286 11603 11684 11990
ILO TV. 0171 1286 1990 1603 0180 1271 1963 0179 0000 1004 1000 1950 1090 1090
Jul 05, 2014 | iLO IWT3206 TV
Tip
Universal remote that works on Ilo TV's
The GE universal remote #24914 works to change your Ilo tv from analog to digital. The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.
on Sep 03, 2009 | iLO IWT3206 TV
Does my Curtis Mathes Tronics model 19001 have a digital tuner?
No,all small tvs CRT tubes analoge tvs design under 35" none of the tvs have a digital tuner inside of it tv Tuner signal board.Must get a signal through a Digital Converter box to recieve a free on AIR broadcating channels from a Digital broadcasting signal.Tvs that are analoge CRT tubes design that have a Digital Tuner design inside of it are only some DLP tvs analoge CRT tube design 40" and above have it only.
Aug 09, 2011 | Curtis-Mathis CM19011 TV
I have an ILO tv 32" I need to repalce the remote
The GE universal remote #24914 works to change your Ilo tv from analog to digital. The code is in the book that comes with the remote (code: 0189). I use this remote myself. It works just as good as the original ilo remote. This remote can be bought at Target for under $10.
Jun 14, 2010 | iLO IWT3206 TV
I got a ilo tv and i cant figure out what the code is for a universal electronics remote help
The only remote I was able to find that work all Ilo features is the GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.
Apr 19, 2009 | iLO IWT3206 TV
Analog or digital
Hi, Lucky you, your ILO Tv has an ATSC tuner which is digital. This should Fixya!
Mar 05, 2009 | iLO Televison & Video
LG hdtv lcd wont turn on will only go to blue screen
How old is the set.. If you its relatively close to being out of warranty LG will probably cover the repair. Contact them at 800-243-0000.
Dec 07, 2008 | LG 42LC2D 42 in. LCD HDTV
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Can't get out of digital mode back into analog
My TV just did the same thing.  All you have to do is turn off the tv, unhook your cable antenna, then restart the tv with the antenna unplugged.  Then go to tv menu, and this time turn the digital scan off.  I really hoped this helped someone!
Jul 23, 2007 | iLO 2600 Television
Televison & Video Logo
43 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
