The cool select pantry and crispers are collecting water in the bottom. I have read online that i need to take off something inside the refrigerator to defrost.? Thought it was frost free. So far it is just water and no ice.
SOURCE: refrigerator collects water at bottom,
at the top of the fridge section at the center back there is a drain assy/ tube for defrost water to exit the unit and go to the bottom of the outside, this is most likely clogged up. disassemble and clear drain line, hook back up and call me in the morning.
SOURCE: problem with cooling and fan on frige
no fan then no cooling!
try to localise the problem by removing the fan and powering it up direct from mains. if it works then problem is not with fan
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
SOURCE: samsung fridge: RF267 ABRS I have
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Check
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
Timer Problem
Water
from Freezer
Refrigerator
heatman101
