Question about Whirlpool Washing Machines
Washer will not spin but motor runs, when i put it on spin cycle i can hear the motor start but the agitator remains still
  • Whirlpool Master
  • 1,527 Answers
Hello any spin problems could be down to the module circuit board this controls the speed all the best
shaun
Posted on Aug 03, 2009
Kenmore 80 series washer model 110 doesn't fully drain when cycle complete
With the lid open, try to turn tub by hand. If you can you may have a bad clutch. If you hear the washer agitating at the begining of the cycle without any water and filling at the end of the cycle, replace the ATC switch. Try spin cycle and open the lid, if you don't see the tub turning, but hear the motor, check motor coupler, or if it never spins after you close lid, check lid switch. These are the most common solutions to this complaint.
Sep 02, 2014 | Washing Machines
I have a Frigidaire FTF530ES1 front load washer that doesn't spin or agitate. The door lock light comes on and I don't think it is that. It fills with water, then you can hear the clicks for each cycl
Good Morning Vickie,
I understand that your Frigidaire washer, model# FTF530ES1, will not spin or agitate. I also see that the door lock light came on so you checked the door latch, due to it not unlocking right away. Now, you have removed the back panel and restarted the cycle, to find out that the motor is not coming on. There is a possibility that it could be the motor, or it could be something completely different that is causing your washer to not spin or agitate. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why it is not spinning. I hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire model fex831fso
can you hear motor trying to run if so . there are 2 things to check agitator has a mechanical device that when it spins it grips the agitator and starts to spin . its like a coupling . also the motor two ha a direct coupling attached to gear box both items are made of plastic in time they do break down . but if you motor runs on a belt and does not run then does it work in wash cycle if so motor ok but selector switch not working properly. if both cycles don't work motor start winding has burnt out can you smell burnt insulation around motor if so need new motor . if thi does not help you google you washer machine on line and you might get a break down on what other possible cause that could effect you washing cycle . but google brand and model number of washer.
May 14, 2014 | Frigidaire Washing Machines
My washer wont rinse. It seems to have a hard time spinning, any suggestions?
do you hear the motor running ,it will drain but no spin,this has no belt in it it's built just like a whirlpool washer because whirlpool owns maytag now and this washer has a motor coupling,i would check this first,do you know if the agitator is working or do you hear a grinding noise when it's running?watch this video and you don't have to disconnect the wire harness to the motor if you don't want to,i don't just put motor off to right side still connected
http://www.youtube.com/watch?v=9K1KHEogf3c
Apr 09, 2013 | Maytag Centennial MTW5800TW Top Load...
Will not spin
Probably needs new carbon brushes, these are usually easy to find on the internet
Apr 20, 2011 | Kenmore HE2 Plus Front Load Washer
AGITATOR WILL NOT SPIN, WATER WILL DRAIN BUT NO SPIN
Does your motor sound like it is running in the agitate or spin cycle or is it quite? If the motor makes no sound, then you need to replace the lid switch with this part.
If you hear the motor running in the agitate or spin cycle but you don't see any action, then replace the motor coupler with this part.
Dec 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer is not spinning and clothes are extermely wet top load 3.5
Hi, Well try to set the washer on the regular cycle, large load and let it fill. After the washer fills to the selected level, the motor should start and the agitator should start agitating.
If you hear the motor running, but the agitator doesn't move at all, do the following:-
Stop the washer and set the timer on the spin cycle and let it run.
If the washer motor runs and the washer empties the water from the tank, but it won't spin, that is an indication that the motor coupler is not turning the transmission at all.
The motor coupler is made of two pieces of plastic called fingers and a hard rubber piece that goes in between the two fingers. One of the fingers is attached to the motor and the other finger is attached to the transmission. The had rubber round piece goes between the two fingers. When one of the plastic fingers breaks, the motor is no longer coupled to the transmission and the washer will not agitate or spin dry the clothes. The reason that the motor coupler breaks before it should, it is that the user overloads the washer. People stuff the washer with too much clothes, big comforters, small placer rugs, snickers, etc.
Another reason is that the washer is used every day; normally the washer is used 3 times a week. So if you have a washer that is 5 years old and you use it every day, it has the wear and tear of a washer that is 10 years old.
Replacing the motor coupler is not hard to do, once you see how the repair is done. You will save at least $100 by replacing the motor coupler yourself.
Thanks!
mannu_rakesh
Aug 21, 2009 | Washing Machines
Will not spin
The problem is a broken motor coupler.
Set the washer on the regular cycle, large load and let it fill. After the washer fills to the selected level, the motor should start and the agitator should start agitating.
If you hear the motor running, but the agitator doesn't move at all, do the following. Stop the washer and set the timer on the spin cycle and let it run.
The motor coupler is made of two pieces of plastic called fingers and a hard rubber piece that goes in between the two fingers. One of the fingers is attached to the motor and the other finger is attached to the transmission. They had rubber round piece goes between the two fingers. When one of the plastic fingers breaks, the motor is no longer coupled to the transmission and the washer will not agitate or spin dry the clothes. The reason that the motor coupler breaks before it should, it is that the user overloads the washer. People stuff the washer with too much clothes, big comforters, small placer rugs, snickers, etc.
Thank You for contacting Fixya.com
Aug 01, 2009 | Whirlpool Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
23 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
