SOURCE: I have an ariens zoom 1540 hydrostatic mower. One
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered.
SOURCE: Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
SOURCE: I have an Ariens riding
Click here to download the Parts Manual .
Click here to download the Repair/Service Manual.
SOURCE: I have and Ariens 1540 model 915043 lawnmower.
Hey Duchi, Mr. Phil Walker is probably correct I use Jacks small engines Frequently for parts they rarely don't have what you need. Try psep.biz also they are both very good sites for parts!
SOURCE: Cant find the PTO deck belt for a Ariens Sport
I own this model as well. The manufacturer issued a "cutting improvement kit" for this model number. The belt number has changed as well. The number you now need is # 07242200
I am in the process of ordering one for mine right now. Good luck!
