Question about Garden
Mower made huge cloud of white smoek and shut off . mower was cutting off after 2 minutes, filled oil, replaced spark plug, changed fuel fitler. mower ran about 5 minutes, then made backfire noise and a huge, puff of white smoke emerged. i shut engine off immediately
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Check for spark at the plug.
If the engine has points and condenser . check to see if the points are good.
If electronic ignition, then it is likely the ignition module is the cause
Posted on Aug 02, 2009
I have toro 195cc tec carb. Mower runs one.minute then cuts out. Have good spark. Replaced carb. Removing fuel cap doesnt help. Carb jet is clean. Swapped plugs with another toro. What am i missing?
Tankfilter (sludge problem) Gasoline faucetfilter the fuel hose connections , fill up your oil level if in doubt of it after know the right level try to unconnec for only a short time the Oil monitoring cable
May 13, 2017 | Toro Garden
Just replaced air filter, fuel filter, and plug. Ran good for 10 minutes then started spuddering and died. Restarted right away and huge cloud of blue smoke came out. It spudders for a minute and dies
Blue smoke is oil. Have you checked you pcv? (Pollution control valve) it usually runs from one of the valve covers to the airfilter unit.
Apr 02, 2016 | Cars & Trucks
Hi I have a Craftsman Lawn Mower 225 and i bought a 40w oil and put in it and it started leaking and ommiting huge white smoke. what should i do?
Hi Manny First thing is Drain all the oil back out. You have most certainly overfilled it. Try and get as much out as you can from the same place you filled it from. Leave it tilted back until it stops running and then put the mower level for half an hour. Check the oil level now and clean the spark plug and replace it. There will still be oil in the air filter due to over filling. Only put oil in one egg cup at a time until its below max on the dip stick. Run the mower for 20 minutes and burn the smoke off. It may smoke for a few times but thats ok.
Aug 24, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
My mtd yard machine (leaf blower) started billowing white smoke. I shut it off and now it won't start again.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug.
Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
Nov 11, 2012 | Garden
Our Husqvarna YTH2148 mower has been in the shop twice and we can't figure out what's causing black, sooty fouling of the spark plugs.
Hi, change the engine oil. It has become contaminated with fuel. Also fit an inline fuel tap and turn it off whenever the mower is not in use. Basically the carby has leaked fuel into the engine oil, the engine then draws the fuel vapour from the oil through the crankcase vent into the carby creating the problem you have. Regards Phil.
Jun 03, 2012 | Husqvarna Garden
Tractor will not start unless you poor gas into the carburetor. When it dose start it let out a small cloud of white smoke I have changed the fuel filter,spark plug & air filters on the tractor. It has...
It sounds as if your carb. needs cleaned, the fuel line is obstructed or the fuel filter is stopped up. All of these will prevent fuel from moving throught the carb. to the engine.
Jul 10, 2011 | John Deere Garden
2003 cadillac cts - white smoke after replacing spark plugs
it will byitself just drive it a bit. the valve cover seals or plug tubes need replacing
May 29, 2010 | 2003 Cadillac CTS
Garden Logo
288 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
