Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Toshiba 65hdx82 Picked up from friend, tv was in cold garage 28 degress for a couple days..Brung home pluged in and screen was blury wavy took about an hour to start seeing clealry. After acouple hours pic looked good except for top half wavy not straight lines. A line going straight down would be wavy, But middle of tv down was good. In morning turned tv on same thing took about 30min to see clear again What is This help>>>>
  • 4,402 Answers
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Posted on Dec 18, 2007
Muffled sound, blury picture
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as
Feb 27, 2011 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65hdx82 has a squiggly distorted side to side picture from all inputs. It gets slightly better after it is warmed up but still very bad. When you go into a menu screen that seems to be OK.
Ur convergence is the problem.U know how to solders?Tries websites.Tv repair, for convergence kit,replaced what in the kit.
Dec 15, 2009 | Toshiba 65HDX82 65" Rear Projection...
Toshiba rear screen projection tv theaterview colors wavey? It no longer is visible, the colors are separated
1.) It sounds like you have a convergence problem; in the customer menu with the original Toshiba remote select convergence--if blue or red will NOT move in some direction you have a bad convergence IC.
2.) This set uses 2 STK-392-110 convergence chips; they and any open resistors around them need to be replaced and the set adjusted.
3.) If you are able to do this repair yourself you can save a lot of money--Most TV shops will charge 300-400 for this type of repair on this set.
4.) If you cannot do the repair yourself look in your area--now is the slow time of year for TV repair shops---if they say it "has to go to shop" keep looking----almost any good tech can do this repair in your home in about an hour--I have done hundreds of them here and charge 200-250 total depending on brand and model.
5.) I am here to help people and if you have questions or need advice let me know--the two chips this set uses you can buy on Ebay for about 12 dollars plus shipping.
I do this here for free, so if this information has helped you give me a vote here---let me know by replying here if you need more help.
Sep 14, 2009 | Toshiba 50H82 50" Rear Projection...
34/58 screen damaged from cleaning.
If this is just the shiny "screen protector" on the tv, then yes, you can just use a peice of plexiglass or acrylic..
Jan 14, 2009 | Toshiba 65HDX82 65" Rear Projection...
Distorted Picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Warped picture Toshiba 65HDX82
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
please mark the post with a fixya
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
