a
arvind chhabra Posted on Jul 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica Minolta c284 error p-21 - Konica Minolta Office Equipment & Supplies
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 03, 2019
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910198
Points
11959
Clean the sensors under the transfer belt, replace the transfer belt, also run gradation prints outs to check each color and run gradation procedure
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jul 19, 2008
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Anonymous
  • 145 Answers
  • Posted on Dec 03, 2008
SOURCE: konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Anonymous
  • Posted on Mar 08, 2010
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
2answers
Konica Minolta Bizhub C454. How to download firmware please?
C454 and C454e firmware - Page 2
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
May 4, 2019 - Re: C454 and C454e firmware. Hi there, I hava Konica Minolta Bizhub C454 with ROM Version: b-IZHUB-c454 - imgbb.com
May 5, 2019
UPDATE FIRMWARE ON c454
Jun 19, 2015
Bizhub latest firmware?
Mar 10, 2022
Firmware question
Jun 19, 2019
More results from www.copytechnet.com
Updating the Firmware of This Machine
Konica Minolta Manuals https://manuals.konicaminolta.eu > contents
User's Guide. bizhub C554 C454 C364 C284 C224 ... A firmware for this machine can be downloaded from the Internet to update the machine firmware.
Download Center - KONICA MINOLTA
konicaminolta.ge https://www.konicaminolta.ge > download-centre
The download center of Konica Minolta! Find everything from driver to manuals of all of our bizhub or accurio products.
My Konica Minolta c284 keeps displaying Automatically replenishing toner even after I've replaced the toner
After replacing with new toner it keeps on running for a while and indicates with a message "Automatic Replenishing Toner" again and stopped.
Konica Minolta c284 is showing white line only in cyan. DRUM CYAN ITS OK, DEVELOPER ITS, TRANSFER BELT ITS OK. THE PROBLEM ITS IN CYAN, Print with white line in all entire sheet.
Clean the slit glass below the cyan drum something is blocking the LASER from writing the image on the drum in that section of the cyan image unit
Printer is showing an error C- E301 on bizhub c284 printer
Firmware Bug
  • bizhub C224/C284/C364
Special firmware version (Web browser LK-101v3 support; Filename: GQQ-65 A1610Y0-F000-GQQ-65.exe)
Special firmware version GPQ-65 (Filename: A1610Y0-F000-GPQ-65.exe)
Notes:
1. HDD Format will be necessary when CE301 or CED01 is displayed.
2. Please refer to attached Program Release Information prior to installing the firmware.
Konica minolta c284 indentaions on paper
Sir mam are you sure it is not happening before fixing does your transfer belt (Shine y looking thing inside the machine when you open the right side of the machine) Does it have only one pic finger in the middle is that where the nick is located. I believe you transfer belt is causing it not the fixing unit. Stop a copy before fixing does the nick move on different copies
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Default administrator password
1234567812345678
Konica minolta c284 error p21
P-21: Color Regist Test Pattern Failure; Secondary Transfer Atvc Failure; P-22: Color Regist Adjust Failure
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
