Question about HP Pavilion F1703 17" LCD Monitor
How do I open the HP Pavilion F1703 17" LCD Monitor so I can check or fix PC board connections causing my monitor to turn off at times. (My power adapter is good voltage).
If there are no screws holding the covering on then there maybe a "snap/barb" type fastener. Theres a special tool that is nothing more than an "angled tool" which can depress and keep barb out of way and you wiggle a side free, more than one is preferred. NO NOT FORCE it but depress if that what it uses, otherwise you'll break it off, though flexible. Think of angle as in a ramp that slides into place and hits barb and pushes out of way so it can be pulled through hole from behind. Also, it need not be pushed down too hard, otherwise the barb is forced against side and removal is still hard. I hope you get the idea.
I used a small screw driver and gently wiggled and snapped at the corners and the midpoints around the moniter.
Posted on Aug 05, 2009
My monitor, hp w2007, shows for about 20 seconds when turned on then goes blurry then black how do i fix???
The most common problem that causes the screen to go to a black screen is due to bad capacitors in the screen's power supply board. The bad caps are the cylindrical and will appear to have bulging tops. 66c561df-0d01-416a-ae23-71f3b3965c88.jpg
Oct 24, 2010 | HP W2007 LCD Monitor
What can I do to fix my hp pavilion tx2000 because it shows a black screen when I turn it on but everything else works fine and it even worked perfect when I connected it to another monitor by vga
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | HP Pavilion TX2000Z Notebook
Blank screen,pwr sup appears to ok, fans runs, pwr light on
The issue seems to be due to defective video card on the notebook. Connect and external monitor to the PC and check if it works fine or not. You can follow the steps listed below to connect an external monitor.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your PC is under warranty, contact HP to get available options to get the notebook repaired under warranty.
May 26, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion zd8000 got my first horizontal line.
A horizontal line on your LCD display is either caused by the video chip on your system board or the LCD screen itself. Either way it will not cause you to lose data on your hard drive. It is a video problem.
By connecting an external monitor from a desktop PC to the back or side of your notebook and switching to it by using your function keys (see manual), you can see if the problem is also on the monitor (meaning video chip problem) or stays only on the notebook LCD (LCD problem).
The video chip problem means you will need a system board. The LCD problem means you will need a new LCD panel. In rare cases, reseating of the ribbon cable on the back of the LCD panel will fix the red line.
Jun 18, 2009 | HP Pavilion zd8000 Notebook
Hp 1703 Video for 1second then Black but can see it but wery dark
sorry, not really a solution, but may help point you in right direction. I have similar or same problem with my monitor but is an f1903 (HP). I recommend you look at the f1903 board postings to see those answers. Several seem identical for fixes and fix may possibly be cheap, but unfortunately noone has posted how to open the monitor up to actually check it inside. This is the tricky part, as seems no catches or buttons are present and removing back screws do not let the monitor case open without some type of special trick or move. If you figure it out, please tell us all! Thanks
Jan 30, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp pavilion f1503 wont stay on
is your computer still running after the screen goes blankl
Jun 09, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Dell flat screen
REPLACE 2SC5707 IN POWER INVERTER BOARD.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
MY HP PAvilion F1903 19 " gone black blank
Problem is generally dry solder joints around the inverter transformer on the inverter PCB.
Feb 16, 2008 | HP Pavilion F1703 17" LCD Monitor
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion F1703 17" LCD Monitor Logo
280 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
