Question about KitchenAid Architect Series KBHC109JSS Electric Single Oven
My kitchenaid built-in high speed microwave oven Model # kbhc109jss was installed a couple of days ago....making an annoying humming noise (not when cooking, only when it is sitting idle) any ideas ??
4 Suggested Answers
SOURCE: Oven unit not heating up - Kitchenaid KEMX377GWHO
This sounds like a blown thermal fuse, a common problem. What model oven was this?
Posted on Jan 14, 2009
aroracaty2
  • 503 Answers
SOURCE: My kitchenaid 30" built in
what you need to do to fix up oven back again
is that you will have to locate the element of your oven it has develop a lick-age from it some air get escape from it and
the element is the heat provider for your oven that allow it to carry out it function has an oven it is always in silver colour and it is connected to the maize (the wire or the hose from the gas ) which supply power to it
unscrew the oven from the back and trace the wire or the hose that connect to the element
please do this with care to avoided more damage on it
OR
You have one or two possibilities here, one is your control board is going out. The second and most likely problem which is usually associated with this error is that the Latch to the door, or switch is failing causing this message to appear. You need to replace the latch to fix the problem. A new latch can be bought from the place you bought the oven or from RepairClinic.com
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 29, 2010
SOURCE: Kitchenaid Suberba #4450786A Microwave/Oven Combo. Microwave
microwave light is burned out. Need a replacement. What part # is it and can I order it online?
Posted on Aug 22, 2011
Will not turn on after using selfclean
Hey there, does it not turn on immediately after you use self clean? Or will it work once oven has cooled down? Due to very high temperature during self clean, oven may need to return to a safe temperature before next operation...
May 22, 2011 | KitchenAid Architect Series KBHC109JSS...
After self cleaning the oven won't open up
Use a small piece of cardboard to engage the lock motor and open the door. The thermal fuse on the rear will also more than likely need to be replaced
Apr 22, 2011 | KitchenAid Architect Series KBHC109JSS...
My kitchenaid 30" built in microwave/convection oven beeps all the time. I have to turn the power off to stop the beeping. when i turn the power on the beepeing starts. I am able to use the microwave...
Well is there any error code on the digital display of your Microwave/oven?
Do you mean how to keep it from beeping when you press keys, or is it beeping by itself?
If the microwave oven is coming on or doing anything (beeping) by itself, this is very dangerous and can result in a fire.
First of all you cam leave it unplug for half hour, it helps you to reset your microwave/oven. If further you have the same problem please reply to the questions.......
Good Luck!!
Thanks
Jul 27, 2010 | KitchenAid Architect Series KBHC109JSS...
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Built in Convection Microwave Oven KBHS109SSS
no reset buton persay but fuses and control boards. MICROWAVES emit and store HIGH VOLTAGE nad should only be access and repaired by trained proffessionals. NO JOKE HIGH VOLTAGE. like your DEAD VOLTAGE
Nov 20, 2008 | KitchenAid Architect Series KEMC308KSS...
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
DOUBLE OVENS FROM KITCHENAID
Redhead Do nothing and call the manufacturer. Your oven has one year warranty. Gendos...post back
Mar 22, 2007 | KitchenAid Architect Series KEBC278KSS...
KitchenAid Architect Series KBHC109JSS Electric Single Oven Logo
49 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
