Question about Universal Garage Wireless Keyless Entry System
Door randomly opening by itself
Just installed a keypad for entry and now find garage door opening all by itself periodically. This did not happen before the keypad was installed. It is a Liftmaster door and the keypad was also purchased from Listmaster.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Maybe new keypad is shorting out from moisture or say a staple too deep into the wires?
Posted on Aug 07, 2009
Why does my LiftMaster garage door opener open the door at random?
basically,first check and clean the lid switches or sensors and or got broken switch and not on it`s proper position.
Jul 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin Liftmaster keypad entry does not worek
It will only take a 4 digit program code. After you program the code, and then enter that code to open the door, hit an additional number on the keypad. Some need the additional digit to act like an 'enter' key.
Aug 16, 2017 | liftmaster Chamberlain Garage Door Opener...
I have no access to my garage i loss my remote and i have no doors to enter the garage. but i have a keypad outside the garage
If your opener has quit working and you have a vault garage, a hole will need to be drilled so a special tool can be used to reach and pull on the release rope. Calling for service is your best bet. After entry has been made and the opener repaired a mechanical release can be installed in case this happens again. The mechanical release is keyed for security purposes.
Jun 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a 2265R 1/2 hp garage door opener, and I'm wanting to install a wireless keypad. Which keypad is compatible with my particular garage door?
You need to give the proper model number. It is on the end of the motor unit closest to the door. Also the manufacturer.
Jan 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
Sometimes the door opens randomly by itself. I haven't pressed any remote to make this happen. How can I prevent this from occurring?
This usually happens with either a bad wall control or the wiring to the control. Staples used to hold the wires sometimes cuts through the insulation and causes the door to open.
Sep 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cannot get keyless entry to work. Bought new keyp...
That keypad should work with your opener. I suspect the keypad is bad if you have other remotes that work. If not it could be the logic board.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opening by itself
Most likely you are receiving an outside wireless signal that is activating your garage door. A neighbor nearby could have an opener that matches your wireless frequency. I live near a military base where years ago the base installed some wireless equipment that caused my door to automatically open. My suggestion would be to change the frequency code. Open up your wireless remote button. On most openers there will be a number of small rocker switches which are marked ON & OFF. Using a pen set these switches to a different configuration and then do the same at the wireless receiver which is located next to the overhead garage door motor. Be sure the opener and receiver's switches are set to the same configuration. This should take care of your problem.
Aug 07, 2009 | Universal Garage Wireless Keyless Entry...
Access Master Garage Door Opener opens by itself
The most common cause of this is a bad wall control or the wiring going to it. The wall control goes bad from use and the wiring sometimes has intermittent short caused by the staples the installer used.
Jul 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
New code entry does NOT override old code on Craftsman 315 keypad
yes. Press the learn button for 8 seconds to clear the remote memory. Reprogram all remotes and keypad
Feb 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless entry pad for garage door opener
THE FREQUENCY OF THE UNITS ARE PROBABLY NOT COMPATABLE THEY CHANGED ABOUT 2 YEARS AGO.
SORRY - I THINK YOU NEED A NEW KEYPAD TO GO WITH THE NEW OPENER.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Universal Garage Wireless Keyless Entry System Logo
228 people viewed this question
Top Universal Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you an Universal Building Material Expert? Answer questions, earn points and help others
