Question about Cell Phones
I have a palm treoo 650, If I set it down or don't use it for awhile and it is turned on, it does'nt want to start back up. the light below the antenna is also red instead of green when this happens.
  • braddunnllc Aug 02, 2009
    That does not work either. I have to take the battery out of it for it to start back up.
    Not yet
  • Cell Phones Master
  • 13,433 Answers
Try plugging it to a charger when it happens and see if it turns on.
Also you could perform a hard reset to restore the pda to the factory default settings it may fix the problem, unless its a hardware issue, bad battery for example.
Posted on Aug 02, 2009
  • Ekse Aug 02, 2009
    have you tried hard reseting the palm?
    Hard reset is performed differently on different models, check palm website for hard reset instructions: CLICK HERE FOR PALM RESET INFO PAGE
Palm treo 650 unlock
Hi! The solution to your problem is to contact your service provider. They can help you in this matter.
I hope this was helpful! Have a nice day!
*please don't forget to rate my services :)
Sep 03, 2011 | Palm Treo 650 Smartphone
Is there a way I can revert my Palm Treo 650 back to original factory settings
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Mar 11, 2010 | Palm Treo 650 Handheld
I forgot my password on my palm treo cell phon
unfortunately, the password is made for protection from accidental or intentional access. The only way to bypass this would be to perform a hard reset and then hotsync your phone with your computer to put your contacts back on your phone.
For performing the hard reset that reformats your phone to factory condition, please follow the instructions below:
1. Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset
2. Let go of the red phone button when you see the Palm screen.
  1. 3. Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
    4. Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
    5. HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process.
Dec 26, 2009 | Palm Treo 650 Handheld
My palm treo is stuck on spanish and I have no idea how to change it back to english.
The only way to reset this to english is by performing a Hard Reset. It will remove all information on the phone BUT after it reformats it gives you the option to select English or Spanish.
The hard reset is performed by following the instructions below:
Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset.
That should solve your problem! Hope this helps!
Dec 24, 2009 | Palm Treo 650 Handheld
My son's Treo 650 powers on (keypad lights up but screen does not light up.) My son attempted to switch the case from the silver to a black and now it will not work. Help?
it may need a software rest if it don"t work go to reinstal software first chake it out
  1. Hard reset:
  2. Press and hold the Power (on/off) button on the front panel of your device.
  3. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  4. If you see a progress bar (see below), keep holding the Power button.
  5. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  6. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Warning: A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything.
HotSync note:Some third-party applications change the way your device backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks,
Jul 04, 2009 | Palm Treo 650 Smartphone
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
Palm Treo 650
Ihave a PALM TREO butIT IS not a phone and I had the same thing happen to me.
What worked for me was # 2
If you have not tried it yet try this!
1). Press the reset set button on the back of the Palm.
2)This is a little bit more memory destructive and you might want to back up you data cause it will wipe out everything!
hold down the power key and press the reset button!
May 26, 2008 | Palm Treo 650 Handheld
Palm 650 stuck in loop
you have to hard reset it. Remove any software that you just install.
May 21, 2008 | Palm Treo 650 Handheld
Receiving MMS on Treo 650
That soulution dont seem possible with Palm treo 650 running Palm OS
Dec 13, 2007 | Palm Treo 650 Handheld
Complete uninstall of palm desktop?
How I uninstalled Palm Desktop for the 7135: Suggest this step: 1) Find your Palm files, all of them, most likely /Program Files/Palm, and make a copy of the folder, call it Palm Backup. That should leave all of your existing information as is, just in case 2) Using the control panel, find and remove Palm Desktop (Start, Control Panel, Add/Remove Applications) 3) Suggest you optionally reboot. 4) Now do the install of your new Palm Treo 650 software. This is what I did, and all is well. I had different problems when I decided to go back to my 7135. Seems that using the same techniques does NOT remove the PalmOne software, lots of residual modules, and even if I did a delete of the entire Palm directory, there must be links everywhere. The 650 has extraordinary capabilities, but in the end, I went back to my 7135.
Sep 12, 2005 | Palm Treo 650 Handheld
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
