Question about Haier HD451E Dehumidifier
(New Unit) Motor Runs, Does Not Extract Moisture
Just unpackaged a Haier HD451-T (not the 451E that was closest in your dropdown menu). The moisture control knobs and fan appear to work normally, the little lever is touching the round pad on the collection bucket, but it does not extract ANY water from the air, not one drop!
    Guru:
  • 588 Answers
Try setting you temperature or fan speed lower this may help.
In order for the unit to remove moisture the coil has to be below the dewpoint.
Posted on Aug 10, 2009
It runs, but why doesn't it extract water?
The compressor has to run to extract moisture. You may be hearing just the fan running.
Nov 23, 2015 | Dehumidifiers
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
Dehumidifier does not extract moisture - just runs and runs
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Oct 11, 2010 | Frigidaire FDF50S Dehumidifier
Unit runs but will not puu moisture from air....possibly the compressor has kicked off due to control problems. Model HD456E Haier 45 pint dehumidifier
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 02, 2010 | Haier HD656E Dehumidifier
The dehumidifier isn't taking the moisture out of the air.
is the compressor in the unit hot to the touch,or are the coils freezing and thawing when it runs<if so you probably need to add some R-134a refrigerant,these type of units are notorious for losing all or part of their refrigerant charge,but unless you have the equipment to remove old refrigerant and vacuum the system down and recharge it it can get costly
Apr 15, 2010 | LG LHD45EL Dehumidifier
Unit runs but does not extract water.
Assuming there is moisture in the air, it could be several things. Be sure the unit is clean and the compressor is running. The outlet line from the compressor should be warm and the return cold. If they are not and the compressor is operating you either have lost refrigerant or the compressor has failed.
Good Luck,
Gilsh
Nov 28, 2009 | Dehumidifiers
Dehumidifier Brand haier HD456E does not pull water and the tank is empty, after 24 hours of running with water on wood floor. Can't find manual or online info for this model.
I have 3 HD656E Haier Dehumidifier with the same problem runs but no water in bucket. How many did the Haier company make with this problem?
Apr 12, 2009 | Haier HD656E Dehumidifier
Haier HD451E Dehumidifier Logo
139 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
