Question about Mitsubishi WD-60737 60 in. HDTV
How do I set my tv to accept my blue ray? I just bought a 60in Mitsubishi hdtv and the manual was lost during delivery. I have the blue ray connected to the TV but can not figure out how to get the TV to accept it.
  • Mitsubishi Master
  • 19,396 Answers
The TV does not need extra settings.
You can just check that TV is set to HD mode or Auto.
Normally you connect using HDMI or component video, then turn blue ray on, then use the Source button on TV to find the channel.
If that does not go, try using a different HDMI input on TV.
If still no luck unplug power from TV and player , do the connection on port HDMI 1 and start with all attached.
Remember to keep both devices off when you swap HDI cable, that is important.
Posted on Aug 02, 2009
I have a mitsubishi 840 series 3d hdtv when i connect my blu ray player to it all i get is a blue screen. How do i get the dvd player to work?
These are complex devices and a simple text solution is not readily available. A thorough understanding of the user manuals for both devices is important. Some useful instructional videos are available from the following link:
https://www.mitsubishi-tv.com/support/troubleshooting#threed
The hdmi cable from dvd to tv must be connected to the appropriate ports. The correct input source must be selected on the tv, the dvd must be playing a compatible disk. The appropriate software level must running on the tv, etc, etc etc.
Dec 30, 2017 | Mitsubishi Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Cinemanow activation code
  1. Set up the Blu-Ray player and connect it to the Internet with a wired or wireless connection.
  2. Check for, accept, and update the device's software if prompted. Instructions to do this should be found in the device's manual.
  3. Activate your Blu-Ray player on the CinemaNow website. Do this on the Internet from your computer.
    • Create an account.
    • Connect your Blu-Ray player to your account. There are two ways that this can be done.
a) Input the PIN number provided during the signup and activation process.
b) Input the PIN number provided on the application on your device, and then input the activation code into your device using the remote.
4. Select a movie and enjoy.
Create an account.
Jul 20, 2014 | Samsung Televison & Video
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I have a 60in Mitsubishi tv that keeps shutting off and the light on the front goes from green to to red or orange blinking. We can only watch tv for a minutes at a time and it keeps happening. Really...
It's too hot. Get out your owners manual or download one and it will tell you how to remove the bulb housing. Clean it and re-install. Make sure the TV can get sufficient ariflow around it.
Dec 09, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Mitsubishi WS-65807 and blue-ray compatibility
that tv set is only good enough to receive a 1080i signal at the DTV INPUT. unless you can change the output of the blue ray it will be outputting 1080p
Mar 01, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-65313 and blue ray
that is a load of bull trying to sell you a newer TV. If your TV has component video inputs, you can easily connect it to a blue ray player. One thing though is that this TV will not be capable of 1080p resolution but will work fine with 720P and 1080i and at 1080i you probably wont even notice the difference. Get the player from bestbuy and run to the closest walmart and pick up a component video cable for less than 20..
Feb 28, 2008 | Mitsubishi WS-65313 65" Rear Projection...
65 mitsubishi model ws 65411 trying to use blue ray
The Tv can only handle a 1080i imput you need to go to the settings on the blue ray player and turn off the HDMI and select component with an output of 1080i. The TV will not accept a 1080p signal
Apr 26, 2007 | Mitsubishi WS-65411 65" Rear Projection...
Mitsubishi WD-60737 60 in. HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
