Question about Konica Minolta Office Equipment & Supplies
Konica bizhub C351 copier with a C9401 error code
We have a customer that appears to have a new Konica bizhub C351 copier with 0 copy count. They did not purchase it from us but want us to repair it. It is missing the ADF/Platen cover and stand. The optical drive cable on the full speed unit had come off the pulley and was originally in a bind but we repaired this by placing it back on the pulley and all moves freely now. When you turn on the machine it comes up with a C9401 error code. “It did this before the cable repair as well” We are aware that this could be associated with the exposure lamp, but since the exposure lamp uses a HV transformer what is the best way to test this area? Also what else could be the problem? Any help would be greatly appreciated.
  • Konica Minolta Master
  • 1,297 Answers
To you need a mechanical adjustment.
A. Adjustment of the scanner motor timing belt. This adjustment must be made the scanner motor assy has been removed,or the scanner drive cables have been rewound.
1. Remove the IR rear cover.
2.Remove 16 screws and the reinforcement frame.
3.Loosen the 3 screws that secure the scanner motor mounting bracket.
4.With the scanner drive gear set screw located on the right hand side as shown on the left,slide the scanner motor assy to the left and check that it is returned to the original position by the tension of the spring.Perform this step three times.
5.Tighten the three screws to fix the scanner motor assy into position.
B.Focus positioning of the scanner and mirrors unit. This adjustment must be made in case the scanner drive cables have been rewound
1.Slide the mirrors unit to rhe center until it is pressed up against the cutouts in the rails.
2.If the mirrors unit is not pressed up against the cutouts,loosen the adjusting screw to which red paint is applied of the mirrors unit and press the carriage up against the cutouts.Then tighten the adjusting screw.
C.Scanner position adjustment.This adjustment must be made if the scanner drive cables have been rewound,focus positioning of the scanner and mirrors unit must be completed.
1.Slide the mirrors unit to the position shown on the left.
2.Secure the scanner in the position shown on the left using the 2 scanner positioning screws.
3.Make the FD-Mag. adjustment.:
FD Mag setting range :0,990 to 1,010 in 0,001 increments.
If the specified width om the copy is less than 298,5 mm increase the settings.
If the specified width on the copy exceeds 301,5 mm decrease the settings.
Adjustment procedure:
1.Call the Tech.Rep.Mode to the screen.
2.Touch these keys in this order : Machine Adjust - IR Area.
3.Position the color chart correctly so that the original reference point is aligned with the scale.
4.Press the Start key to make a copy.
5.Check point D( D:300+/- 1,5 mm) on the image of the copy.
6.If the image falls outside the specified range,touch FD-Mag.
7.Change the setting using the up/down key.
8.Press the Start key to make another copy.
9.Check the image on the copy to see if the specifications are met.
10.Make adjustments until the specifications are met.
Good luck,please answer.
Posted on Aug 02, 2009
ERROR CODE CALIBRATING
Might require having the firmware up graded get a konicaminolta tech out to up grade the firm ware from a secure konicaminolta web site.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 06, 2014 | Konica Minolta bizhub C351 All-In-One...
Appear code F023 when I Have started c351 bizhub
Your firmware (Operating Software for the copier is bad) Will require a tech, as the firmware for the copier is located on a secure web site only access able via Konica Minolta Dealership and KMBS, they like to protect there firmware
Feb 09, 2014 | Konica Minolta bizhub C351 All-In-One...
Minolta bizhub 162 error code 32
In Konica Minolta bizhub 210,162,211,163,182, error code "cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem, simply call your technical service representative to solve this problem.
If you want to remove this code by yourself then please perform these actions attentively.
1-Turn the machine ON.
2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
11-Restart the machine.
Oct 04, 2010 | Konica Minolta bizhub C351 All-In-One...
Our machine shows C9401 default, can you help us in solving this problem
Not exactly sure if the model is the same but on a C351 the C9401 & C9402 errors are as follows:
16.6.81 C9401 Exposure lamp failure to turn on
16.6.82 C9402 Exposure lamp turning on at abnormal timing
Parts to check:
Scanner Assembly
Flat Cable
Image Processing Board (PWB-C)
Step Action
Corrective steps in order of suggestion:
Check flat cable for proper connection and correct or change as necessary.
Change Scanner Assembly if necessary
Change PWB
Apr 29, 2010 | Konica Minolta bizhub C450P Laser Printer
Bizhub C351 the top feeder does not feed the paper anymore. how do i get into the service menu?
well with konica there is like 3 service modes
hit the utility key..than push details..
than
in this order
stop 0 0 stop 0 1
Jan 08, 2010 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Aug 05, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
Aug 02, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta Bizhub c351
you have to clear the counters in tech rep mode.
Utility - counter - details- then the following sequence....
stop-0-0-stop-0-1 then press counter - life - then highlight the parts you changed and press the C button, then exit .
Jul 23, 2008 | Konica Minolta bizhub C351 All-In-One...
243 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
