Question about Samsung HT-Z210T Theater System
Samsung HT2510 disc will not load says disc error
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
Won't load DVD
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. that fixed mine that had the same problem
Apr 21, 2009 | Televison & Video
Hello I have a Samsung HT-HTX22 home cinema. It wont play any discs at all, it says Loading then reads no disc or disc error, can any one help. Regards Joe
ik heb een vestel tv ,en krijg geen geluid via mn 5.1 ht-thx22 speakers omdat hy niet voorkomt op de lijst van het manual dus mijn vraag is ondersteunt hij ook vestel tv ,s of moet ik een samsung tv kopen m.v.g. D.Suverein
Apr 11, 2009 | Samsung HT-Z310T Theater System
Viewing Discs on Samsung VP-DC161
RE; smasung DC 161(i) pal and possibly other models The reason why there is no disc message when there is definitely a disc is installed is because the disc programming has malfunctioned, Its because of Samsungs poor design, after powering up the camcorder and inserting a disc, the disc will load and a green flashing light appears for a minute or two while loading if the Samsung camcorder is switched off while loading the camcorder will essentailly self destruct and their is no remedy, however that does not mean the Samsung is completely useless,the camcorder can record on a 4 GB SDHC(max 4GB) card using the switch from disc to memory card
Dec 16, 2008 | Samsung VP-DC161 DVD Camcorder
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
Write error
I think i just figured it out. Somewhere else on the web clued me in that the disc got messed up (don't know how). I put in a new disc and it works. Other disc still doesn't though.
Nov 04, 2007 | Samsung SC-DC164 DVD Camcorder
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
Jul 11, 2007 | Samsung VP-DC161 DVD Camcorder
Samsung HT-Z210T Theater System Logo
169 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
