Question about Fujitronic FH-797 Portable Air Conditioner
No Cooling This relates to the Fujitronic FH-797, which has no compressor but is designed to have water brought from a bottom pan up through the unit and then back down, dripping through what is called an "evaporation radiator"; this "radiator" is similar to a standard cooling pad. Theoretically, a fan blows over the water-saturated pad and the evaporative process provides cool air. I can't get the unit to dispense any water over the pad, although I have run it for hours with the "cool" switch on. Therefore, the unit just blows hot air.
    Guru:
  • 587 Answers
The water pump or the float valve is not working.
Posted on Aug 10, 2009
I have a Fujitronic FH-700B Portable A/C unit that is squealing when I press the Cooler button. I can't find any help or support online as the item is no longer sold - is there a manual or...
SOUNDS LIKE THE MOTOR NEEDS OIL...LOOK FOR ZOOM OIL THIS LITTLE GUY IS A LIFE SAVER.. IT COULD ALSO BE FAN HITTING SHROUD, AND WILL CURE ITSSELF OVER TIME, BUT A OLD UNIT I THINK NEEDS THE FAN OILED..HOPE I WAS OF HELP. HIT THAT YES BUTTON IF'N I WAS .. JAY MOTOR GUY
Jul 21, 2011 | Fujitronic Heating & Cooling
My Fujitronic FA-1310S Air Conditioner makes banging sounds when it's in cooling mode. How can I fix this? Thanks.
if the banging noise only happens when the compressor turns on or off then check the compressor shock mounts .. the compressor is mounted on rubber or spring mounts . if they are out of place or damaged then the compressor will hit the sides as it comes on or turn off .. if the unit was stored upside down or on its side then there is a good chance that the shock mount is out of place ..
Aug 15, 2010 | Fujitronic FA-1310S Air Conditioner
How to dowload movies?
Hopminto a full tub of water, insert the unit in the tub with you and plug it in.
Apr 22, 2010 | Fujitronic FH-778 Air Conditioner
Kenmore side by side freezer side - freezer side drain overflows & leaks on floor
Unusual problem. Most defrost water drain pans are designed to hold all the water the refrigerator can generate. The water should be evaporated by the compressor heat and heat from the coils. Is the refrigerator cooling adequately? Perhaps there is some problem with the compressor and or compressor fan operation.
You might try finding a larger pan and see if you can get it where the existing pan is located.
Oct 15, 2009 | Refrigerators
FA 1300 NOT COOLING WELL. IT SEEMS TO KICK ON BUT THEN TURNS OFF AND IS NOT BLOWING COLD AIR
Hi there. If unit just starts to get cold then the compressor shuts off and if the compressor comes back on after 3 to 5 minutes, the system has a freon leak or the compressor is over heating.
If you are technically inclined, search for leaks using soapy water at all tubing connections.
For overheating compressor: Clean the condenser with compressed air or vacuum cleaner. If still overheating, start switch or start capacitor may be bad.
Thanks
Paul
Jul 12, 2009 | Fujitronic FA-1350 Air Conditioner
Fujitronic 1300 ~ compressor does not stay on and not overly cold
sounds like the units compressor is shutting off. this could be caused by being low on freon, or a dirty condensor coil. the condensor coil is where the hor air exits the unit. make sure it is clean, free of lint/dirt. if it is clean, you will need to take it in to a repair shop and have the coolant leak found/repaired and then recharge the unit.
Jun 04, 2009 | Fujitronic FA-1300 Air Conditioner
No cooling
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Jan 08, 2008 | Fujitronic FH-797 Portable Air Conditioner
Fujitronic FH-776 air cooler
I have looked all around sir, Cant seem to find one.
Aug 03, 2007 | Fujitronic FH-776 2.11 Gallon Humidifier
Fujitronic FH-797 Portable Air Conditioner Logo
129 people viewed this question
Top Fujitronic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Fujitronic Heating and Cooling Expert? Answer questions, earn points and help others
