Question about Dryers
When I push the start button the dryer starts but immediately shuts off when I release my finger from the start button
    President:
  • 1,714 Answers
That's the start relay causing that. It is supposed to energize and stay pulled in to run.
Posted on Aug 02, 2009
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
I pushed the start button on the dryer it turned on but didnot st
The instant you press the button on the console, the motor should start. When it starts a mechanism in the motor operates a switch mounted on the motor (provided w/new motor). That makes a circuit which replaces the action of your finger holding the button by creating a bypass circuit. This bypass circuit takes the start switch completely out of the circuit and keeps the motor running.
Your motor is not making this bypass circuit and needs to be replaced.
Oct 28, 2009 | Kenmore Dryers
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Hotpoint tumble dryer model wt something, colour graphite. The problem is that when I press the start button the dryer comes on and normally stays on when you release your finger from the button, but when...
hi your on/off switch has broken down you will need to replace it it will cost you about £4-£8 it is fairly easy to fit good luck if you need help just ask.
Apr 22, 2008 | Washing Machines
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
