Question about Traulsen 7 cu. ft. / 198 liter Commercial Freezer ULT27
Very loud compressor in traulsen freezer
Just recently installed a new compresser in traulsen freezer. It is very loud. Anything that can be done about this?
  • 122 Answers
It's probably a hermetic compressor. Nothing can be done. It's got an internal rattle, possibly defective valves, or freon was avercharged.
Posted on Sep 23, 2009
I got a restriction in my freezer
this happened to me once, when I brazed up the comp some flux ran down inside the pipe causing an intermittant blockage, hope this helps.
Apr 11, 2009 | Traulsen Reach in Freezer - G22010
Freezer compresser short cycling pressures at 45 150 b4 shuting down and re trying, what should normal press, be? if i recover refrigerant the compressor runs longer and brings on e vap fans
You have a restriction in the system or a overcharge.
Recover the system.
Replace the filter/drier.
Pull a deep vacuum.
Recharge according to the nameplate charge.
Mar 11, 2009 | Traulsen 7 cu. ft. / 198 liter Commercial...
Freezer wont cool
This problem could be cause by a few things. Can you tell me if your condenser is clean? If it is dirty, the heat cannot be rejected. Will you feel the large copper line going to the compressor and tell me if it is cold to the touch? If it is not col and your compressor is running you may be low on refrigerant. Also, is the evaporator frozen over? If your evaporator is frozen over you might be low on refrigerant, or you evap fans may be out.
Feb 15, 2009 | Traulsen Freezer G22013 Freezer, Reach-in,...
Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Dec 09, 2008 | Traulsen 24.2 cu. ft. / 685 liter...
Traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Nov 23, 2008 | Freezers
Traulsen freezer URS48DT
Turn cold control to Max. This keeps your compressor running for this troubleshooting exercise. Find and manually advance the defrost timer with a screwdriver or something similar. This will shut the compressor down and bring the defrost heater on. If this happens then you will know that your timer is bad.
If it is not that, the next thing to look at is the defrost heater itself or the thermal overload on your defrost heater. This keeps your defroster from overheating.
Jan 20, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Traulsen 2 door freezer
Traulsen Freezer Compressor Change Out Video
Dec 05, 2007 | Freezers
Traulsen freezer urns for about 2 weeks then stops getting cold enough
Will it restart again? How old is this freezer? Could be start relay loose or a burned wire connection, worn out compressor. Let us Know what you find
Oct 12, 2007 | Traulsen 7 cu. ft. / 198 liter Commercial...
Traulsen 7 cu. ft. / 198 liter Commercial Freezer ULT27 Logo
231 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
