SOURCE: Spreader Settings
I called Scotts, and according to them the Edgeguard Deluxe uses the same settings as the SpeedyGreen 3000.
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
SOURCE: need the setting for a Scotts Pro edgeguard
Hi, W/D here.
The spreader setting instructions will be found on the back of the bag, and you will set your spreader gate opening accordingly.
Best regards, --W/D--
SOURCE: Have Scotts Edgeguard DLX.
I realize this is an older question but in case anyone has a similar question The Scotts Edgeguard DLX equivalent would be the Speedy Green 3000 suggested setting.
SOURCE: I have a Scotts Turf
I was just told by Scott's phone customer service (800-543-8873) that their TurfBuilder EdgeGuard mini can use the same settings as their "SpeedyGreen" broadcast spreader, if your fertilizer lists that one.
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
We do have a general rule, called the 50 by 20 rule which will allow you to use any product in any spreader, but there is some work that will need to be done.
* Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (In your case 2.3 pounds)
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less. In your case i would suggest about 2.75 or 3)
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, you will need to increase the setting accordingly
* If they you up short, you will need to decrease the setting.
