Question about Nakamichi SoundSpace 5 Shelf System
I need to take the speakers further away from the unit - where do i find extension speaker cable and will it affect the sound quality? thank you.
  • pepperring Aug 03, 2009
    thanks for your help
    the problem is that this system uses a cable that has 5 wires in the core as I think each speaker has it's own little amp.
    Sergeant:
  • 263 Answers
Won't affect the sound quality unless you use cheapo cable don't know where you live uk Richer sounds for cable or Maplin ..USA no idea Radio Shack possibly..
Posted on Aug 02, 2009
I want to extend my speaker cables, how should i connect them
The ideal solution would be to swap out the entire cable for a longer one unless you have to...
It sounds like this isn't an option, so your next best choice is to get some extension speaker cable and cable crimp-on connectors or Wire cable connector blocks (see ebay URL with picture below ) from the wiring department at Radio Shack, Home Depot or your local hardware store. The crimp connectors are generally rubber shielded metal tubes that you insert the wires from the speaker and the extension speaker wire. You then squeeze the crimp-on connector with pliers to secure the wires in place.
IMPORTANT...During extension make sure the polarity (+ -) marekd with different color will continue from existing speaker cable.Otherwise you will loose the LOW NOTES -BASS
If you don't have any extra speaker wire on hand, you can pick some up at a reasonable price at Radio Shack or any hardware store. While there are many theories about what gauge speaker cable are best, you're likely starting with fairly thin wire coming from the back of the RCA home theater system, so crimping on a heavy gauge wire will do little to improve your signal quality. 18-guage speaker wire will likely do the trick in most cases. I would likely recommend a different solution if this were a component-based system with individually powered amps, but for an all-in-one system, 18-guage wire will be sufficient.
Crimp-on **** connectors come in a variety of sizes. Make sure the size you choose is appropriate for the wire you use to extend the length of your speaker cabling run. Here again, Radio Shack and the local hardware stores will sell the connectors you need for most of the common wire gauges.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://cgi.ebay.co.uk/SPEAKER-WIRE-CABLE-CONNECTOR-BLOCKS-EXTENSION-/280672581841
Jul 11, 2011 | Panasonic Home Theater System System
JBL Radial -iPod audio system
It should produce sound from al speakers, I see if I can find a schematic.
Oct 29, 2008 | JBL 6-1/2\ Round Coaxial Speaker By...
I have a panasonic SC-HT500 SYSTEM BUT MAIN DVD UNIT IS NO GOOD AND I WOULD LIKE TO BUY A REPLACEMENT AS ALL THE SPEAKERS ARE WORKING PERFECTLY, IDEALLY I WOULD LIKE A BLU RAY UNIT IF POSSIBLE
http://www.retrevo.com/support/Panasonic-SC-HT500-Home-Theater-Systems-manual/id/22986dj593/t/2/
I'd look for another base unit identical to yours (SA-HT500), say, on eBay and buy a BluRay for future compatibility with any components you might decide to upgrade to. Or just skip that part and upgrade now.
On page 6 it specifically says to use only the supplied speakers.
"Use only supplied speakers
Using other speakers can damage the unit and sound quality will be negatively affected."
I'd take that to mean you really don't want to redeploy the speakers to other electronics either. Theater in a Box is designed as a package. That proprietary cable connector is a huge clue and disincentive to attaching it to other electronics.
Feb 07, 2011 | Panasonic SC-HT500 System
I have a leaf in my subwoofer. I'm very reluctant to take it apart. Any ideas? Thanks
How on earth did a leaf get in there?
If it is not affecting the sound quality, I'd leave it especially if you are not keen on taking the woofer apart, I'm afraid thats what you will need to do though if you want it out
Jan 01, 2011 | Harman Kardon Harmon Kardon SoundStick II...
Ihave a sava-500 home theater speaker system i dont have the cord to connect the 2 tower speakers will this affect the sound from the main speaker using the av input
With not all the speakers hooked up, it will definitly effect the sound. The unit is designed to channel different sounds to certain speakers. That's what makes you feel like "you are there" If you have lost the cords to the tower speakers, you can buy replacements. Go to where you bought the unit, a Radio Shack, or other store that sells home theater systems. Enjoy your system like it was designed .
Apr 16, 2010 | Sony SA-VAD900 System
Crackling noise coming from 1 channel
sounds like you are picking up some interference first try swapping out the RCA cables you are using to connect that component. also keep your RCA cables away from any 110V AC power lines.
same thing with speaker cables, speaker wire should intersect power lines at 90 degrees and should not run parallel to power lines.
many people use the wires that come with their components. these cables are thin and offer very low performance a thicker higher quality cable with a gold connector will not only better maintain the quality of the signal being transferred between components but will also have better shielding to protect the cable from picking up interference from other electrical components and power lines.
Also should point out that a blown speaker sometimes produces a crackling sound, swap your left / right speakers and see if the crackling sound still comes from that speaker if it does you have a blown / damaged component.
Dec 30, 2009 | Onkyo Audio Players & Recorders
A215 speakers fuzzy noise
Have you got a power supply unit near the speakers (move any power source away from a speaker). Other than that then one of your cables has a short in it.
May 17, 2009 | Dell A215 Computer Speakers
Speaker cables are too short
Just go to Radio Shack and buy some RCA jacks, the length of wire that you need and a soldering iron. Those inexpensive extension cords (12 and 15 foot) at the dollar store make good speaker wire, as copper is better. Just cut off the ends. Speaker wire from an electronics store is expensive.
If you decide to go to Radio Shack or similar store, the clerk should be able to explain everything to you, if not, run, don't walk to another store. You will eventually find someone to help you. If you don't know how to solder, just go to google and type in "how to solder". I'm sure you'll get plenty of hits.
Post back here for any further questions.
Feb 03, 2009 | Samsung Audio Players & Recorders
LOW VOLUME FROM RIGHT CHANNEL OF STEREO 1 SIDE OF SYSTEM
It seems like the speaker jack tip needs cleaning, or the contact has become bent away from the connector and needs to be re-aligned.  The Passport is a portable system, so after years of plugging and unplugging the speaker jacks may be worn.  Try using the "Stereo 2" connectors. You can also try cleaning the jack with electrical contact cleaner, and. a cotton swab.
Jan 07, 2009 | Fender Passport Deluxe 500watt Sound...
Nakamichi SoundSpace 5 Shelf System Logo
320 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
