Question about Emerson EWL3706 37 in. LCD Television
MY FLAT SCREEN TV HAS BLACK SMEAR ON THE LEFT SIDE
I JUST WANT TO KNOW IF IT CAN BE FIXED OR NOT?
I recently bought a model wd60638 tv which the previous owner had just changed the lamp. I have noticed a black looking smear on the lower right side of the picture screen.
YOU MIGHT DEGAUSSING YOUR SCREEN. I ALSO SOUNDS LIKE YOU MIGHT HAVE A SMEAR OF SOME SORT ON THE SCREEN SO SEE OF YOU CAN WIPE IT OFF. GOOD LUCK.
Jul 01, 2015 | Mitsubishi Televison & Video
New 60" lg TV has a crisp white smear with pinstriped lines
Bring it back. You have done nothing wrong and the dealer may have a Bad Batch of units.
Mar 22, 2014 | Computers & Internet
Vizio 46 inch black screen on left side
Sounds like you either have a faulty LCD panel tab, failed LCD driver board, LCD/t-con panel bad connection, or a bad t-con. You will need to get a diagnoses to be sure.
Dec 15, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
Hello, I have a 40" Samsung LCD flatscreen. My television has a 2.5" diameter black spot on the far left side about 4" from the bottom of the screen, Also we have a dark transparent band across the bottom...
Sorry Sir but your LCD TV got wet... it can be splash with too much water, an animal urinate on the panel, etc....
this kind of black spot is caused when the LCD Panel Terminals got wet, this terminals are located at the lower side of the LCD Panel.
Sep 15, 2010 | Televison & Video
I had a accident with my LCD tv and now the right handed side is black. YOu can still see the left side and sound is good. Can this be fixed or should I just get a new tv?
it would be worth getting a service engineer to lookat it but chances are tha screen is damaged in which case it is probably uneconomical torepair
Jun 29, 2010 | Toshiba Televison & Video
I have a 42" Samsung Plasma. We have had it two years so the warranty just ran out. We have a half inch red line down the left side of the screen. Also, when the screen should be black, there are hints of...
ONE OF TWO THINGS, THE LINE COULD POSSIBLY BE FIXED WITH A SCAN BOARD, BUT NOT LIKELY, PROBABLY NEEDS A SCREEN REPLACED, THE OTHER RED STUFF CAN BE FIXED WITH A X-BOARD REPLACEMENT, BETTER OFF TO BUY A NEW TV
Dec 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Dec 15, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
It started out small but it has gotten larger. A
Dead Pixels. High definition flat screen screens are made in layers. One part is short circuiting causing the pixels ti die. If I were you I would get a new one at a sale or something ASAP because this will just keep happening until it is broke.
Jun 28, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
42 LG Plasma
It can be fixed but about $300 in parts.
May 18, 2008 | LG 50PX4DR 50 in. Plasma TV
Emerson EWL3706 37 in. LCD Television Logo
206 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
