Question about Mitsubishi WS-48613 48" Rear Projection Television
Misubishi WS-65613 Flashing green reset light
Misubishi WS-65613 has a continuous flashing green light. I am a former TV repair technictian and have the tools to fix the set with some recommendations. I assume I will need to secure a copy of Sams Photofacts.
Thanks for any suggestions.
Frank
Austin, Texas
  • Anonymous Dec 13, 2007
    Mitsubish WS55613, continuous flashing green light.
    Tried reset, tried shutting down and powering up. Flashing light does not stop after 1 minute (despite what book says).
    I am not a TV tech, but I am fearless and know how to replace the "3-prongie thing"...
    Would appreciate some direction.
  • BigMahi Dec 19, 2007
    Blinking Green Light from HELL!!!!!! Help!
    Not a real mechanical kinda Dude,but I will give anything a shot to avoid getting screwed by a repair service. Mitsubishi should be ashamed of this quality issue and do something to correct. TV is only 2.5 yrs old....
    Genius:
  • 1,694 Answers
You will not need SAMS on this one,Frank! I fixed four Mits. with
your symptom in the last two weeks.....parts = 1000mf/25v caps
105 degree hi-temp X 4.......Location = DM module...for pix's...
www.Chris@ChrisAndNat.com.....download copy..........
I have improved above procedure....When finished with repair of
PCB.,I place it secure in sockets , with two screws on end of
module back in place.THEN I slide cover down over module
and put the side screws in..........
Be gentle and if you need more help............T.
Posted on Nov 29, 2007
  • Vista Electronics Dec 22, 2007
    Frank,
    What happened to DM module repair ?................T.
    Sorry if website didn't work,I think someone is selling that info now ! ........
    Guest & BigMahi,
    The DM module is large,upright board covered with metal shield.
    Loosen / unplug enuff wires to slide chassis back so shield can
    come off to remove board for repair......T.
I have seen this problem before- you have some bad caps in the DM Module; If you need more information, you can contact me @ larry@rjoelectronics.com or 480-839-6898; Thanks for your interest, Larry from RJO Electronics.
Posted on Feb 02, 2009
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files http://www.eserviceinfo.com/downloadsm/31768/Mitsubishi_WS-55859.html
this is part 2 with 2 zip files http://www.eserviceinfo.com/downloadsm/37351/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
electech
Nov 26, 2008 | Mitsubishi WS-65613 65" Rear Projection...
It will not turn on.
i have the same problem with the ws-65613 ,what do i tell the repairmen or how do i fix it my self.
Nov 09, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Cant start on and the the green light keeps flashing
ardnas1886, can get the 4 new capacitors 1000uf 35v (Radio Shack part # 272-1032) = about 5 dollars
Nov 08, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Mitsubishi WS-48613 48" Rear Projection Television Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
