SOURCE: Removing the battery
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear.
SOURCE: Dyson DC16 Handheld Vacuum Cleaner Manual
Yes! Go to www.dyson.com/support. Click on "using your dyson", then (next window) on "select your model", then (next window) on "select your model" again, then (next window) on "DC user guide". And there you are, you've got a copy of the user manual.
Please remember to rate this response. Thanks!
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
SOURCE: dyson elbow tube clogged
turn the vac upside down then stretch out the hose the stick will eventually fall out
SOURCE: I got a Dyson DC16 handheld cordless.
i have posted a fix on here ,,, its the magnetic transistor sensor on the pcb,,, common fault found the fix today...remove it and solder 1 wire from a+c on my diagram,,its at the top of long board that sticks up into a cavity off the main pcb..behind the serial number,,
remove it and solder a wire...like this
A
B C
SOLDER WIRE TO A + C AFTER REMOVING THE TRANSISTOR.. RIGHT AT THE TOP GUYS OF THE PCB... FIXS IT 99% OF THE TIME PROVIDING U KEEP IT CLEAN,
LET ME KNOW ALL WHO FIX ...CHEERS SAY THANKS,
