posted by jannne on Nov 25, 2007
Speed is alrigt but the pick up arm stays in rest position you can move it bay hand but it want non go down to the record. I have four currents 5v - + and 15v - and +
Best Solution
posted on Nov 26, 2007
You might have a bad cue motor/ass'y. Did you buy this new, or used? Are you the original owner? Did this just start happening? Have you done anything different (moved the unit, cleaned it, etc) to the unit?
If the cue ass'y is bad, then that would require professional servicing.
- TWEAK AV LAB
- TWEAK AV LAB
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Denon DP-47F Turntable
Email this problem
Email this problem
Can you Help with these Turntables problems?
the arm will not return to...
when a play a record and it's... Answer This...
Repair Service
Find Turntable Repairman Near You:
