Remote does not work
I just put a new battery in and it still does not work... is there a reset button?
  • 10,865 Answers
Be sure that the "new" battery is good by testing the battery or taking it to a radio shack store where the clerk will test it for you.
there is no reswet button. Fortunately, a new remote, called a universal remote will serve you well. These are available at radio shack, walmart, etc.
Posted on Aug 02, 2009
What do I do to get the remote starter to work
look for a red reset button on the remove control computer in the car
Dec 14, 2014 | 2007 Buick Terraza
Reset oregon scientific weather station
I always have trouble getting mine to work after changing the batteries, but I have just managed to get it going by doing the following:
taking batteries out of main unit
putting new battery in remote unit and pressing remote unit reset button
re-inserting batteries in main unit and pressing reset button.
i think the trick is to ensure that the batteries go in the remote unit first, then the main unit after that. It has taken me days to work this out!
Jan 19, 2013 | Oregon Scientific BAR206 Wireless Weather...
EeeTop all in one PC wireless keyboard and wireless mouse not working - bayyeries fresh and reset button already checked out
you must keep the batteries out for a few minutes and unplugged then re plug to a new usb port. hit the connect/ reset button on reciever alone with batteries still out of remote then put the new batteries in (lights come on remote you know you have good batteries) and then hit connect on that. that should work if not you must hit connect at the exact same time. thats how i fixed mine.
Mar 12, 2011 | ASUS Eee Top ET2002 20-Inch All-in-One...
My MKJ40653802 remote won't work even after putting in new batteries.The TV is hooked up to sky and that remote works fine + the Tv works on the buttons but not on the remote.Any suggestions
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. (no light means bad remote)
If you do then the problem might not be the remote but the sensor on the set.
IF this does not work then;
you can turn the set off and unplug for about an hour to allow any EPROMs to reset. Next plug back in and try the remote.
If this does not work it
Feb 28, 2011 | LG Televison & Video
My audiovox remote will not turn on tv or change channels - I put in new batteries. I pressed the TV function button to reset but is does not reset to use the tv or dvd
Try put again the batteries.A very simply and efficiently mode to see the remote control is work or not to tested of pressed taste next on radio posted on FM or MW.
Aug 21, 2009 | Audiovox Televison & Video
My remote does not work
Reset remote. If universal remote, put on dvd mode.
  • If your remote has a Reset button, take out the batteries and press the Reset button for 2 or 3 seconds. Re-inset the batteries and try using the remote again.
  • Note: Many remotes have a small hole marked Reset instead of a raised Reset button. To activate the Reset function, you need to push a thin, rigid wire (for example, a straightened paper clip) into the hole to "press" the Reset button. Also, the Reset button or Reset hole may be located under a sliding cover on the lower section of the remote.
  • Remove the batteries and hold down the POWER button for 1 minute. Insert fresh batteries and try using the remote control again.
  • If this does not solve your problem, remove the batteries again and press and release each button on the remote control once, then repeat. Re-insert the batteries and try operating your remote again.
Otherwise you need a new remote. If under warranty call manufacture to see about getting one free of charge. They can also help you purchase a new one if not under warranty.
Jun 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
