Question about Frigidaire FDE336RE Dryer
Does not ignite
Everything works- dryer just does not ignite
  • polishdave42 Aug 02, 2009
    kenmore elite # 110.73932102
  • Mike Smith
    Mike Smith May 11, 2010
    Brand and model number needed .
    President:
  • 1,714 Answers
Is the ignitor 'glowing'? Do you see a glow coming from the ignitor? Look under the dryer to see, I need a bit of info to try and help you...
Posted on Aug 02, 2009
Verify IGNITER glows the easy method
continuity checks on igniters are seldom accurate. An amperage test is the best solution. Igniters are fairly cheap, just replace if it is suspect. They are a wear item that go bad frequently.
Aug 13, 2014 | LG DLG3744U Gas Dryers
My gas dryer burner does not heat. The igniter does not glow even to permit the gas valve to turn on. Everything else works and checks out being good, such as the thermostats, igniter, flame sensor. ...
You could check the igniter by testing to see if 120 volts is at the wiring the igniter plugs into, if 120 vac at that plug the igniter is bad Also need to check THERMAL FUSE,in addation to thermostat,on electric dryers if thermal fuse is out it cuts circuit to motor, on many brand dryers if thermal fuse bad on GAS dryer it cuts circuit to igniter
Aug 12, 2011 | Dryers
The unit just stopped heating and drying the clothes.The burner on my LP Kenmore dryer won't light, otherwise everything else works just fine. I've have taken everything apart and cleaned out all...
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty
Jul 28, 2011 | Kenmore Dryers
The Maytag Atlantis dryer (gas) does not appear to be igniting the burner when it is turned on. The problem has gradually become more frequent over the last couple weeks. Now, it almost never lights up. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Igniter won't glow
I am assuming that everything works OK except you have no heat?
When you turn on dryer listen for gas valve to click(this may take a few seconds).If you don't have a click then the gas valve my be bad or it is not getting power.
Dryer has to be running to check for power only experienced persons should perform machine running power tests.
Let me know If I can do anything else to help.
Mar 20, 2010 | Whirlpool LGR5636L Gas Dryer
The dryer will not heat, everything else works.
If this dryer is electric and everything are working the most probable cause should be the high temp thermostat located within the heating elements and also the overtemp sensor located close to dryer exhaust vent. If this is a gas dryer check the electric igniter located within the burner area.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Neptune Drying Center MCGAWW (No Heat)
Sorry no pilot light but you have ignite, flame sensor and a gas valve...all control heat...
let me know if I can help
krazytech
Mar 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
