Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Leak water at the from door - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
  • 6,784 Answers
HI. check to see if the front door seal is creased slightly. if so, try to straighten it so that it is flush with the door structure when closed. check the drum seal as well. replace the door seal if needed.
Over sudding can cause this as well. make sure you are using the correct amount of HE detergent.
Posted on Aug 03, 2009
Water in floorboard,drivers side.Have checked during rain,but no visual leak
I'd try pouring water harshly towards the windshield, (outside, of course). Next, do the same with driver's side door. If this fails, try again with a water hose. Remember, when it's raining, there's much pressure, especially if you're driving. I would really try to get water to leak into vehicle, it would be much easier with a friend's assistance. I hope this helps!
Nov 21, 2015 | 2006 Jeep Grand Cherokee
There is water leaking inside above my passenger side door when it rains pretty hard?
is the water leak allowing the water to wick up into the headliner or is the headliner getting wet without water coming past the weather stripping around the door?
If it is wicking then fix the weather stripping.
If the water is getting headliner wet with out passing the weather stripping then you have a leaking sun roof.
You can the door seal by sitting in the car while you have some spray water (garden hose) gentle at the frontal and upper door seal.
If not leak there inspect seal of sun roof and real seal with correct type of sealant.
Oct 14, 2014 | 2006 Pontiac Vibe
Lg French door inside ice maker stops working but water flows out the back of the fridge where the water line gores in. Water line is fine and just had a new ice maker put in but it still does not produce...
Sounds like you have to have a leak in the water line somewhere. The water line goes to the top hinge in the door, so the water has to come from somewhere below that point or it would be collecting inside the door and leak out the front. A leak would prevent water from getting to the ice maker, or a leak at the valve could have this effect as well. Check the water valve that gets a call to send water to the ice maker.
Jul 07, 2014 | LG LFX25960ST Stainless Steel French Door...
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Leaking from motor
Water Inlet Valve
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Seal
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
Water leaking from door when cold water dispenser being used
Hello Frank,
The line that runs from under the freezer door and connects to the dispenser is cracked or the connector is cracked. By removing the lower hinge cover ya should be able to see where the line connects to the door and see if it seems to be cracked and leaking their,if that connector is good then the line inside of the door is leaking..in some cases depending on brand the line is easily replacable without having to dis-assamble the entire door
GENE
Nov 11, 2011 | Refrigerators
The water dispenser leaks
The most likely reason for the leaking at the water dispenser is the dual water control valve on the back and near floor is leaking water while shut off. The only option is to replace the water control valve. Sea Breeze
Aug 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Aug 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Washing Machines Logo
178 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
