Question about Technics SL-1200MK2 Turntable
On/off knob, spindle problem
The spindle that makes the on/off knob on the technic 1210 twist has fallen into the deck. How do i get the back off to retrieve it and put it back in again. I have undone all the screws but the back will not budge. Is there something i have missed.
    Guru:
  • 417 Answers
U will have to phone me on this one mate coz it's a big job, but i can defantly help you.i,ve had many a technics in bits & theres a nak.....
TEL:07970306952 Tatty
Posted on Aug 08, 2009
Who can repair my 1210 technics turntable. Power is getting to the deck, as i am an electrian. Ijust need a good repairer.
Depends where you are located. If you are willing to pay for the shipping both ways, I am in Ontario Canada.
Mar 02, 2011 | Technics SL-1210 Turntable
How do i free up the tononig arm on a technics 1210 deck? It is stiff and wont move across the record.
It should really be replaced but you can try adjusting the screw on the top of the arm
Dec 23, 2009 | Technics SL-1210 Turntable
Tone arm pulls back on my technics 1210s
your needles gone.or you've moved the tip by touching it.
try & twist the tip back straight.
A LITTLE TIP FOR YOU ....u should never wipe or
touch the tip of a needle with your fingers coz the greese off your skin ***** them.blow it or use a little fine brush.
Aug 04, 2009 | Technics SL-1210 Turntable
How do i change the speed of technics 1210 mk2 back to the original speed?
if you take off the platter, then undo the plastic board covering and protecting the circuit board...then once you have access to the circuit board...there should be a little blue knob, usually located top right...its basically a matter of turning it untill you are happy with it, unless you have a little mark on the blue knob and the circuit board...if you or someone has done that, then that will be the master setting, of +8/-8 pitch
Jul 21, 2009 | Technics SL-1210 Turntable
Deck fades out when i bring the second deck in (records I mean)
are you running phono pre amps ? are you running pre amps to each deck or one for both decks , if you are running pre amps maybe the power supply is not sufficient to run two decks anymore [ possibly damaged ] but it sounds like a power delivery failure to me . hope this helps
May 24, 2009 | Technics SL-1210 Turntable
Turntable power knob broke..
there should be a metal bit in the middle of that switch housing, sorta like the spindle on the platter, it should have one flat edge just get some pliers and twist the metal bar in the middle clockwise, until you replace the switch that will be the only way to swtich it off and on.
ive done this before many times, and sometimes in clubs the decks are in bad shape, so i always bring pliers, just in case!
Jan 28, 2009 | Technics SL-1200 Turntable
Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
May 03, 2008 | Technics SL-1210 Turntable
1210,s
bad thrust bearing for the platter. use a penetrating oil on the spindle and let stand. then try rotating it after a while.
Sep 11, 2007 | Technics SL-1210 Turntable
Technics SL-1200MK2 Turntable Logo
66 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
