Question about Dishwashers
Our neff dishwasher has suddenly started to go wrong. When you switch it on a push a setting, it fills but does not wash. After about 10 mins it even drops the powder cube but still has not washed, it just does nothing. Really appreciate it if someone could help
  • 10,865 Answers
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Posted on Aug 02, 2009
Neff dishwasher - bottom tray not cleaning - rotary arm not turning
If your dishwasher is 10 years old and you are facing a significant repair cost, it may be time to consider replacement.
Jan 01, 2014 | Neff Dishwashers
We have a neff dishwasher and the pump is draining all the time (even when the door is open) but there is no water in the dishwasher. Is there a way to stop the pump and reset the setting for the flood...
The water which has activated the antiflood device is actually underneath the appliance it is held in the sump tray and this has to be drained before the A.F.D.will cancel.You will have to remove the dishwasher to get at the underneath but when you have got rid of the water you will still have to trace what caused it.The seal on the circulation pump could be a suspect or a pin hole in the drain hose.
Hope this helps.
May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
It fills and runs but doesnt switch off
will it do complete wash if no and it wont fill ... then its leaking the noise you are hearing is the pump kicking the water out so it wont flood your kitchen. 01179512835
Dec 30, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher continually draining
Update to my problems. It is now working. I removed the T20 tork screw housing the pump cover which is situated underneath the filter. I used a sponge and siringe to remove all water. And started the dishwasher a few times to spin the pump and flickout any excess water. I noticed some small bits of food which were removed and I cleaned all filters and put it back together. It didnt work staright away but the pump was not comong on as soon as the door was shut anymore. I did a reset and then selected a rinse programme and voila it worked! Tried a full wash cycle last night and it all seemed to be working fine......
Feb 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff built in dishwasher model no: S4453N0GB/07 When you switch the dishwasher on all the relevent lights swich on, indicating the dishwasher is ready to use. but when you switch the start button it clicks...
We fixed the problem at home. The Start button had a loose connection.unscrewed the panel and pushed all the wires in and were able to restart the dishwasher.
Feb 29, 2008 | Neff 24 in. S4456 Built-in Dishwasher
Neff dishwasher water filling
there is a safety float in there to shut the water off most look like domes under the float is a safety switch take off the bottom kick and see if the float is on the switch if it is check to make sure the switch is good
Feb 18, 2008 | Neff 24 in. S5543X2 Built-in Dishwasher
Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Dishwashers Logo
176 people viewed this question
Top Dishwashers Experts
Owen Barnes
