Question about Kenmore 62872 Electric Dryer
Fuse have changed the thermal fuse dryer still wont start. could i have the wrong fuse./?
  • 943 Answers
Thanks for the question it could be the door switch that's bad lift up the top and check the switch also make sure you have 240 volts at dryer thanks the appliance doc
Posted on Sep 15, 2008
My Maytag Neptune MAH5500B wont start.We thought it was the control board so we change it.And still wont start
Have you checked the thermal fuses? The main cause of dryers not starting is the thermal fuse.
Mar 06, 2015 | Maytag Neptune MAH5500B Front Load Washer
Has power but won't start what's wrong?
Hi Is three sample resolution
1 electric cable broken
2 pushed bottom broken
3 thermal fuse broken
Check cable ,change pushed bottom open the standing cover , exchange thermal fuse open back dryer cover. Usually is the fuse.
Oct 16, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer is dead. I have ohmed out the cord and changed the dryer control board (8546219). Still dead, nothing at all. Any other ideas?
The most probable thing thats wrong causing the dryer to not start is going to be a blown thermal fuse,when it goes out it cuts power to the motor circuit...do you have a display on the front yet it wont start???? or no display??
If you do have a display yet the dryer wont start it very likely will be the thermal fuse,it fits into the blower housing below where the lint filter fits into inside of the door. To access it to check it remove the small lower front panel and it will be on the top of the blower housing,to check it measure it for continuity (ohm it out) with zero ohms resistiance.
If that turns out to be the problem be sure to take apart the blower asm. and clean all lint from it and also check the venting from the back of the dryer all the way to where it exits the house....since the usual reason the thermal fuse goes out is because of poor airflow because of built up lint/blocked vent.
GENE
Sep 22, 2011 | Kenmore Elite HE4 Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Last nite mid cycle my 90 series dryer quit and now i cant get it to do anything. changed the fuses in the fuse box but still nothing . might it be the thermal fuse ?
may be the thermal fuse but here is a website that can help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 10, 2011 | Kenmore Dryers
My dryer is a kenmore 110.61082000 and it wont start. it keeps displaying check lint screen even though it is completely clean and the sensor bar is clean. what is wrong?
The thermal fuse located on the blower housing is blown and since it is wired in series with the motor, power to the motor is terminated, the motor will not run and no dryer function works. Disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to expose the thermal fuse on the blower housing.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the thermistor if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Let us know if you need further advice.
Jan 30, 2011 | Kenmore Dryers
I have a Kenmore 110.63032102 dryer and I put a pair of sneakers in it. It shut off and now it wont even turn on. What's wrong?
Drying a pair of sneakers causes the dryer to overheat and this causes the thermal fuse to blow. The thermal fuse is wired in series with the motor circuit and if it blows, power to the motor is terminated causing the dryer not to turn on. Disconnect power then Pry the lower access panel off with a flat-head screwdriver as shown.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Let us know if you need further advice.
Jan 26, 2011 | Kenmore Dryers
Start light on but wont start
Well most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting. So first of all you may check out the fuse.
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 62872 Electric Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
