Question about Zenith Z50PX2D 50 in. Plasma HDTV
Black verticle line
1 inch black verticle line on screen. Sometimes it goes away for a few minutes.
  • 1,284 Answers
You most likely have a bad address board or the conntection is dirty between the address board and the PD (Plasma Display Panel). This is not a do it yourself repair as any damage to the cables to the PDP would require a PDP replacement.
Posted on Nov 25, 2007
My Sharp flat screen has verticle lines running down the screen in various colors and every once in a while a picture with pop up but then fade away. The capacitors all look fine and i have no idea wh
the lines is the screen its self there is a board that the screen fits to over time it heats up and comes away from the screen and you get lines, you can sometimes push on the screen top to get them back but its only a temp fix you will need to take the screen out and remove the cover and put some shims in place on the screen. this is not a job for the faint hearted as it is a delicate job.
Mar 28, 2014 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I have a verticle black line about 3 inches wide on my panasonic
Normally when a line appears on the screen of a plasma or LCD it indicates the TV needs repair. There are circuit boards inside the set that, if bad, will cause problems with the picture. The only troubleshooting the manufacturer will offer is to unplug the TV for 30 minutes. If that doesn't solve the issue, the unit needs service.
Call Panasonic at 800-211-7262 to see what they're willing to do for you. If you're under warranty they will service the TV for sure. If you're out of warranty they still might give you a break--they've been known to do that.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 04, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
Verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
hi..the probelm is due to the video circuit board.
only when you have a problem with the video
circuit board you will get such type of
you have to check the video board immediately.
check it out..
thank u..
rate me..
Feb 28, 2009 | Vizio P42HD Television
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
181 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
