Question about Hotpoint Freezers
Hotpoint freezer fza34 red warning light will not go out all food thawed all reasons why checked ... what could it be ??
2 Suggested Answers
  • 670 Answers
SOURCE: Hotpoint freezer, High temp light on & all food thawing
It's probably the defrost timer is getting stuck in the defrost mode. What it does it it periodically interrupts power to the compressor and sends power to the defrost coils to allow any frost on the cooling coils to melt to keep them clear of ice build up. This is typically a mechanical timer and sometimes the motor fails and it stop turning and if it fails in the defrost mode, the compressor never turns back on no matter how warm the freezer is.
You can confirm it is the timer, by tracing the wires from the compressor to a little 2 by 2 inch box which is the timer. On one side there should be a round hole with a plastic cam. You should be able to turn that cam with a flat screw driver or a coin. Just give it a slight turn until you hear a click. After you turned the cam, the compressor should start. If it does, then it is the timer.
Posted on Jul 01, 2010
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Why does the red light on my VF70 freeze r stay on all the time?
Warning light (red)
If the temperature warning light ? lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food.
Dado
May 05, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
My hotpoint future fza34 is leaking from underneath
you need to get to the back of fridge and ul notice a tray full of water ontop of the compressor. remove tray and empty water out. when replacing v important to make sure it is sitting level on compressor again.
there is also an underlaying prob here, maybe alot of condensation on shelves also??
ensure doors are closing properly and saels are in good shape, also avoid putting warm food in fridge and make sure liquids are covered. this should stop tray filling with water and leaking
Sep 23, 2010 | Hotpoint Freezers
Jun 29, 2010 | Freezers
The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Apr 10, 2010 | Freezers
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
Hot Point FZA34 freezer just 1 year old stopped working. Power light on. No sound from freezer and started to de-frost.
Call you authorized repair person immediately. You dont want to loose your food.This could be simpley the thermostat and they usually have part on hand if you give them the heads up.
Cheers
Al
Sep 11, 2009 | Freezers
HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Jul 28, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Freezers Logo
155 people viewed this question
Top Hotpoint Freezers Experts
Justin Duby
Justin Duby
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
