Question about Asko T781 Electric Dryer
Asko T781 dryer trips on over temperature
I just moved into a home with a Asko dryer in it. The problem is it trips on over temp and I need to pull the unit out to reset it. I called the previous owner and he said to check the condensate bin, the ventless basket and internal lint screen, all were clean and the condensate reservoir was not full. I had a service tech cone in yesterday and he honestly said he was sure what the problem was but he was going to investigate it. Do you have any clue? Thanks
  • eric57chevy Jan 25, 2008
    I have the same problem. I took the front off and removed all covers and hoses to clean everything out. The air flow through the exhaust is still minimal.
    The only area I didn't get to, because I don't know how, is the heating element. There does not appear to be a removable cover on the inside of the drum and the back of the machine has a lot of nuts and screws that I don't want to remove for fear of not being able to replace it all.
    The repairman wanted $300 to replace belt and clean the machine!?!
  • cindysadler Apr 01, 2009
    Just moved in and the washer and dryer came with the house. I'm stumped. It trips after just a few moments and when I open it up, steam comes pouring out! It's the first load I've tried to dry and it consists of about 6 towels. We have the owners booklet for the washer (in 4 languages!) but no booklet for the dryer. Water tray is empty and lint trap is free. Any ideas?
  • 126 Answers
The problem is probably that it is much lint in the fan, and/or in the back of the drum, so the air is unable to cirkulate fast enough. OR it can be that you are overfilling it with laundry.
Posted on Jan 24, 2008
The display on our T781 Electric dryer is "dead"
Do I use the USB socket to charge my battery in the S529. it switches on then goes to MSDC mode.
Oct 16, 2013 | Asko T731 Electric Dryer
Asko 7005 dryer, start capcitor is cracked and has hard goo coming out the side, dryer wouldn't start and stay running, now it won't start at all. Could the capacitor be the problem or do you think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jun 17, 2011 | Asko T781 Electric Dryer
Asko dryers
Akso makes "condensing" dryers (Models T721 and T781) that condense the moisture wich then is directed to a drain. The T701 is a vented style dryer so I'm a little confused.
Dec 15, 2009 | Asko T701 Electric Dryer
I have an ASKO T781 Dryer that suddenly will not power up. Any ideas? Someone told me to pull the fuse panel? I do not have the manual available. Any ideas or what tool to use to pull the fuse panel. Also,...
I just had this same problem, The fuses were not attached to anything. I stumbled upon a black button, that looks sort of like a gromet. Push that, it's a reset button. If it clicks, there you go. It could mean something else is wrong, but that should be a starting place.
Sep 01, 2009 | Asko T781 Electric Dryer
My dryer is making an increasingly noisy rolling sound when in use. It is an Asko T701 model
sounds like your drum guides or felt thats wore
out or something stuck inside there rubbing
Jun 17, 2009 | Asko T781 Electric Dryer
Asko T780 Dryer Vibrating/Grinding noise
Sounds like a bad roller. You'll have to remove the drum to get at them. Even a free one may make noise at speed. Use high temp grease. Also check roundness. And don't forget the belt tensioner roller, just don't get any grease where the belt touches.
Apr 23, 2009 | Asko T781 Electric Dryer
Disabled neighbor was given an ASKO T780 dryer, but it doesn't heat up. What could the problem be so I might be able to fix it for him?
most likely if the dryer does everything except heat up the heating element is bad if you take it apart it will be directly behind the holes inside the dryer
Jan 15, 2009 | Asko T781 Electric Dryer
press the black reset button on the back.wash door filter and condensor,then try again hope this helps.
Mar 16, 2008 | Asko T781 Electric Dryer
Asko T781 Electric Dryer Doesn't Turn On
Have you reset the cut out on the back? its a little black button that you push in until it clicks. If it does not click, then it probably wasnt the problem. The next most likely cause is a melted fuse holder inside the box on the rear where the power cord goes in. There is a bypass kit available to repair this problem from ASKO, as the fuses are not needed. If you are able to do some simple wiring, you can do this. Otherwise find an AUTHORIZED asko servicer and they will know what I'm talking about. Good luck!
May 30, 2007 | Asko T781 Electric Dryer
Asko T781 Electric Dryer Logo
311 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
