Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
ROBOT GOES BACK AND FORTH 2 FEET ONLY
YELLOW ROBOT ONLY GOES BACK AND FORTH 2 FEET
  • 640 Answers
There are several things to check for with these pool cleaners. First, make sure that there are not kinks or knots in the cable that would restrict movement. Make sure that there is not hair, fabric, or other debris in the impeller. This can also cause the back and forth movement. Check for debris or leaves caught in the axle bearings.
Posted on Oct 11, 2010
I have not used my Robo Kleen for several years. It was in storage in the basement. I put it in the pool and at first only moved a couple of inches. I manually rotated the wheels and they are very...
try keep working the wheels, it might free up. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 11, 2013 | Smartpool Dolphin Robo - Kleen Above...
GOOD HEATER CCORE AND STILL NO HEAT.
Hello! The heat switch sends a ground on a Yellow/Green wire to the Mode
Control motor which operates a door directing the heat to to your feet you can watch the door as you apply a ground to the Yellow/Green wire (pin 8) on the motor plug to see if the motor is defective..Guru.saailer
Dec 12, 2011 | 1996 Honda Accord
When I place my Robo-Kleen in the pool, it now only travels about two feet, rocking back and forth. Occasionally, it will go a few additional feet, but then stops. I also don't seem to be getting the...
I would first check for obstructions in the front and back wheel axles. Then, take the top grill off and make sure that the impeller is not jammed. It sounds more likely to me that you are having a problem with the pool cleaners gear box or drive system. If it is still under warranty, send it back to the manufacturer. If its not, you will need to have it repaired by an experienced pool repair person.
Jul 20, 2011 | Smartpool Dolphin Robo - Kleen Above...
My son just received a robosapien for Christmas. I put batteries in it and the remote. The eyes only light up. The robot does not move or speak. The robosapien my son received is about 2 feet high,...
Sometimes the robot may get stuck in sleep mode. Press the power button on the robot's back (by his shoulder blade) once, and if nothing happens, wait 2 seconds and press it again. The Robosapien should begin its wakeup procedure.
Jan 06, 2011 | Wowwee Mini Robosapien Humanoid Robot
We found out tpday that we have 19 leaks in our inground pool liner which is not quite 2 years old!! The only thing we've changes this year is we purchased a Barracuda Robotic pool cleaner. Have you ever...
It will have a strong suction to the pool floor and could grind bits of sand into the liner. You might want to try a Arneson Pool Vac.
Be sure they put cork feet on it though so it goes easy on the liner.
If and when you replace the liner be sure to put an under-liner down first. This will help with problems that run along these lines.
Sep 13, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My Nitro Wall climber only cleans a small area back and forth for the entire 3 hour cycle. It litterally rocks back and forth in 1-2 second motion spurts. The drive wheel in the back seems to be working,...
The pump motor is responsible for the programming of the unit and it is failing. You will need a new pump motor installed to correct the issue. For information about sending the unit in for repair you can try our site at www.arrowpools.net or the manufacturer at www.smartpool.com.
John
Aug 19, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
Transformer turns on but robot in water don't turn on no movemen t or water flow
I had same problem unplug unit wait for 30 seconds and try it again I had to do this 3 times this a.m. I am having problems with it only going 2 or 3 feet.
May 25, 2009 | Smartpool Dolphin Robo - Kleen Above...
Amber light on my dirt dog wont start blinking when it try and schedule it
Dear woodzylovgf, Sat 02-21-2009 2:44am EST (USA)
RE: iRobot 1100 Dirt Dog Bagless Robotic Vacuum "Schedule"
Try clicking on the following link for scheduling @
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=124&p_created=1154460853&p_sid=4dgcL_qj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTksMTkmcF9wcm9kcz00MiZwX2NhdHM9MCZwX3B2PTEuNDImcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXNjaGVkdWxl&p_li=&p_topview=1&prod_lvl1=42&prod_lvl2=&prod_lvl3=&prod_lvl4=&prod_lvl5=&prod_lvl6=
iRobot has Great Service & Support!
If you need further assistance, please give a more detailed description of your problem...
Remember not to close any web sites but click your back and forward arrows to get back and forth!
Please click back here and rate me!
jackiaria
Feb 21, 2009 | iRobot 1100 Dirt Dog Bagless Robotic...
Roomba Discovery wiggles back and forth and turns over and over
No matter your model Roomba, this occurs when Roomba has gone "crazy." Its brain is no longer working properly and you can usually tell this when you've cleaned the dickens out of it a few times and the behavior is still the same. There's only one possible user fix and that is to take out the battery, hold down the power button for 20-30 seconds then reinsert the battery.
If that doesn't do the trick, IRobot might send you something called an Ozmo which you put in the data port to rewrite Roomba's brain. Unfortunately this requires it to be under warranty unless you get lucky. Good luck, all!
Jul 12, 2008 | Roomba Robotic Floor Bagless Vacuum
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
275 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
