I find Overcooked! 2 Steam CD Key is cheaper than other game cdkeys on https://www.m8x.com, it's this game more boring than others?
SOURCE: Nintendo ds N5 card stuck on loading screen
found solution to R5:
download latest firmware (1.19 at present) and unzip
format MicroSD to Fat or Fat32
Copy firmware onto MSD in this order ONE BY ONE !!!!!!
This step is very important!!!!
1. DS_MENU.DAT
2. _AXMENU.DAT
3. _DS_MSHL.DNS
4. _SYSTEM_ folder
5. moonshl folder
Then load your .nds files into the root.
I've had absolutely no problems with this card so far and if
installed correctly it works brilliantly!!!
SOURCE: New R4 card never loads
You should check if the R4 card is actually R4 SDHC, because the firmware of R4DS is not compatible with it. If it is SDHC, go to this website http://rs320.rapidshare.com/files/140174805/English-1.21.zip to download the firmware for your card. If there are any roms on it, you should save them somewhere else, for you have to format the card first (do this in windows by going to 'this computer', then right-clicking on the SD card from your R4 and then select 'format'. Warning! Never select 'quick format'! This could do damage). Now your card is completely empty. Copy the files you just downloaded and unzipped to the card (5 files; _system_, moonshl, _DS_MENU.DAT, _DS_MENU.INI and _DS_MSHL.NDS). Now put the SD card in the R4 and it should work properly :) I had the same problem, and I have just solved it *grin*. I hope this was useful.
SOURCE: Already have numbers saved to
How Do I Copy Contacts From My SGH-d807 Phone To The SIM Card?
To copy an address book contact to the SIM card follow the steps below:
While in standby mode, press the left soft key for Menu
Select Address Book (8)
Select Contact List (1)
Select the desired contact entry, stored in your phone's memory, using the navigation keys
Press the left soft key for Options
Select View (1)
Select one of the contact phone numbers, using the navigation keys
Select Copy (3)
Select SIM (2)
Press the left soft key to Save the single contact phone number to the SIM card
Note: Each phone number for a contact must be individually saved to the SIM card
PS-Not sure about updating/replacing entries though, which is what you may have been asking about
SOURCE: Saving numbers to sims card.
go to phone book then managment then copy all to then sim card.
SOURCE: nintendo DS not recognising R4DS CARD
Had this problem too. Solved it by cutting a small piece of thin card (cigerette box} or anything similar , and inserting it along with the r4 card to make it a tighter fit.Insert it in the back side of the r4 card, not the side with the metal contacts.hope this helps.
