Question about MicroBoards Orbit (ORB-4201-01) Burner
Have a #27606 orbit 6 station timer - does it take 110 volts when a station is put on manual the timer says "no AC power" does tahat mean to te timer or nto te valve email - ausdecker@gmail.com
2 Suggested Answers
damneddle
  • 1607 Answers
SOURCE: where can i go to
Hi there!
You can find the manual in this link:
http://www.hardwarestore.com/media/pdf-misc/607980.pdf
It is in PDF format so you need an acrobat reader to open it. If you don't have one yet you can download and install it for fre here:
http://get.adobe.com/reader/
Thanks for using fixya!
Posted on Jun 01, 2011
How do I program model # 57114 from station a to b to c
The model of Orbit sprinkler timer you show has 4 or 6 zones for watering. I provide link below for instructions for use. Reading it, I don't think this timer has A, B, C, schedules if that's what you mean (whole different settings on each). Other timers commonly do however that feature in my experience is rarely used. If you don't like this timer, Home Depot has a $20 timer 4 station that I've found is easier to understand than many of them, also a 6 station for a little more same type (think is Orbit not sure). May need to zoom instruction shown from the link.
Jul 09, 2016 | Hardware & Accessories
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
https://www.hunterindustries.com/sites/default/files/IC_EcoLogic_EM.pdf
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
How to wire
First check the solenoids by performing a continuity test on all of them. For all the solenoids that test good, power each one with 24 volts to make sure that the plunger moves. Then go to the timer and initiate an ON cycle for, say, zone one. Go to the zone 1 connector on timer and check for presence of 24 volts ac. If not present try zone 2 for output. If nada then there is something wrong with the electronics of the timer.
Mar 28, 2015 | Orbit 6 Zone Automatic Irrigation Watering...
Orbit station manual
if timer is plug-in, check outlet for power
if timer is hardwired, then push breaker fully off then fully on
Aug 24, 2014 | Hardware & Accessories
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
No AC fault in Orbit Sprinkler Timer Model 57896
Call Technical Support at Orbit. The 800 number should be listed in the instructions.
Apr 17, 2014 | Orbit Underground 57896 6 Station In/Out...
"my orbit easy dial 6 station quit working in auto
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
Aug 11, 2013 | Orbit Irrigation 57856 6 Station Easy Dial...
Orbit timer 57899 no AC
Transformer is probably burned out. If it is a indoor timer buy a new 24V transformer. If it is a outdoor timer buy a new one.
Apr 28, 2013 | Orbit 9 Station Super Dial Irrigation...
Hardwire the orbit outdoor sprinkler timer
Reset the timer? This will sometimes resolve many problems.
Are you sure the conduit has 120Volt? Is the timer connected to single breaker?
Or is circuit 240V? Timer connected to double breaker.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
What do you mean green wire to negative?
What else is on the conduit circuit?
Motors, fluorescent lights, and other electronics can interfere with electronic timers.
Run extension cord to timer from another electrical source and see if problem continues.
Re-post question with model number so timer-electricity expert can read the troubleshoot section of manual.
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/pdf/Rona-91026-water-timer.pdf
Aug 01, 2012 | Orbit Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
MicroBoards Orbit (ORB-4201-01) Burner Logo
620 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
