* Check your warranty. Call for service.
*** following is for information only.***
* Range hood lamps are usually available at hardware stores; Lowe's, Home Depot, or a lighting store. Take the old bulb to store for an exact replacement. There are many different bulbs though these are common for track lighting, etc.
* Note; not all range hoods us Halogen. You will find LED lights starting to show up on hoods. I'm not convinced they are the best choice (LED) for a heated area as LED is an electronic device that is sensitive to heat. Halogen's have another use (used under the hood). They do produce heat as with counter top heat lamps used at restaurants. Though not a lot of heat, you can still feel the warmth from Halogen lamps when turned on High settings.
* Golden Vantage (specs); https://www.amazon.com/ask/questions/asin/B00ASQJ7RS/2/ref=ask_dp_iaw_ql_hza?isAnswered=true#question-Tx2BW19EX2L2JVQ
Aloha, ukeboy57
SOURCE: How do you change a halogen bulb in my dacor range hood
Believe it or not - they just unscrew like regular light bulbs. There is supposed to be a suction cup that came with the hood to replace the bulb - we lost ours. I was able to remove it by using a little bit of pressure on the face of the bulb and twisting it back and forth. The other bulb was stuck, so I made a "handle" using duct tape on the face of the bulb.
SOURCE: Indesit cooker hood.
some have fuses, some dont. i know that if you dont have the vent hood hooked up correct the heat can melt the wires on the inside. so make sure the vent is hooked up right.
SOURCE: Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
SOURCE: Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
