Question about Garden
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
Toro 6.5 hp pushmower shuts off after ~ 5 mins of running. It sounds fine, and when it shuts down, it shuts down quickly. I have changed the spark plug, changed the air filter, added octane boost to gas, changed the oil, tried to run the mower with the gas cap loose. The problem remains the same. After it shuts off, it will restart after a few minutes wait, but again will only run for a minute or so. What's left to try? Thanks for any ideas!
  • jawindley Aug 03, 2009
    I hammered down the ground and the sparkplug connection. I cleaned the carb with carb cleaner. I drained the carb. I did not remove it completely. This is a project for next Saturday!
    I also drained the gas out completely and replaced with "fresh from the pump" gas.
  • 3 Answers
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Posted on Aug 02, 2009
Why does it run for 10 mins, then stops?
Loosen Gas cap and see if that helps. Many times the Gas tank Vent gets clogged. When engine runs, it creates a suction and starves the engine of gas.
OR
If the engine was stored with gas in it, sometimes the Rubber seat in the carburetor deforms and wont let the gas flow into the Carb Bowl at a fast enough rate to keep up with the running engine. The bowl empties (after 9 minutes) and the engine quits. Takes a while for the bowl to refill (5 minutes).
Jan 16, 2016 | Toro Snow Blowers. Power Clear 621 QZR 21...
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
What Oil so I Need for a Toro lawn mover 6.75 HP ?
I think you are talking about a Toro pushmower with a 6.75 Briggs motor on it. If so; it is a four stroke motor and requires 10w-30 motor oil.
If it has a dipstick then its a 4-stroke. If there is no way to add oil to the crankcase and no way to check the oil level then its a 2-stroke ( ie. lawn boy and some really old snapper pushmowers)
Oct 06, 2012 | Garden
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have the 6.5 hp self propelled model, It starts fine and runs strong for aprox 5 min then dies, seems to die when it gets hot possibly, the die time is always the same aprox 5 min. Once it dies it will...
I don;t know what engine is on your mower but if it has the self contained electronic ignition coil I have seen happen on several engines. It would run good for several min. then the spark just stops . And it will not spark again until it sets and cools . Just make sure it is the ignition that is not working.
Sep 15, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro LX 500 Riding Mower with Kohler Courage 22 motor. I was cutting grass and it started hesitating and eventually shut off. It will start but only runs for a bout 30 sec to 1 min before it shuts...
When you had the fuel filter off, did gas flow freely from the hose? Sounds like maybe the tank has dirt in it blocking the fuel line. Other than that, maybe there is dirt in the carburetor bowl.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Toro Lawn Mower With Toro Power Tools
Engine dies
Check and clean your gas tank. If still a problem there might be dirt in the carb.
Sep 09, 2009 | Garden
Electrical Problem?Runs great then shuts down,let it sit runs fin
Sounds like the ECM is bad. This is a common problem, when the ECM gets hot there is a solder joint that seperates, it makes contact again once it cools down
Jun 17, 2009 | 1998 Plymouth Grand Voyager
Husqvarna 24 hp mower shuts down after about 5 or 10 min.
I WOULD LOOK FOR AN ELECTRICAL (IGNITION) SHUTDOWN,CHECK WHEN IT SHUTS DOWN WITH SPARK TESTER TO SEE IF IT IS FIRING.
Mar 22, 2009 | Husqvarna Garden
Garden Logo
393 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
