I am trying to remove the filter at the front of my washing machine but it is well and truly stuck. Any suggestions how to unscrew it please?
  • 5 Answers
SOURCE: How to remove filter on Indesit WIXE 127 front loading washing machine
You will find there are something like coins trapped in the filter, stopping it turning, get some pliers & try turning it backwards & forwards to dislodge the blockage. If this doesn't work you may have to force the filter & buy anew one
Posted on Nov 03, 2008
amgm
  • 32 Answers
SOURCE: can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Posted on Feb 19, 2009
barkencoa
  • 3463 Answers
SOURCE: HOW TO REMOVE FILTER ON FRONT OF MACHINE
Turn it anti-clockwise to remove and clean, and yes there will probably be some water run out, so have a cloth/s ready to mop up water.
If the filter handle has a screw in it, undo the screw before trying to move it.
Please rate my solution.
Thankyou.
Posted on Jan 24, 2010
Testimonial: "after trying to get some answers this was just brilliant there was a screw and the little filter cap came of with a slight turn thank you very much "
SOURCE: Aquarius wf541. Am trying to remove pump filter to clean .
think yourself lucky my plastic broke when i was unscrewing it or tying to ended up cutting my knuckle open on the shard of plastic and water pumping out all over my kitchen is there somewhere that you can purchase the cap from and how do you get the broken one off???
Posted on Feb 23, 2010
  • 9 Answers
SOURCE: How can I unscrew the drain outlet at the bottom
Keep trying to unscrew it, as it should come right out for cleaning. A little water will come out too so put a small tray under the machine first.
Look at my other solutions, as for DOOR light flashing.
Posted on Apr 04, 2010
My bosch maxx 5 washing machine is locked and giving a key sign on the screen
Maybe your filter is blocked this is usually located at the front on the bottom lift the front of the washing machine up slightly say like place a hardback book under it would be around the right height then unscrew the filter usually large round plastic circle with a line type handle to unscrew once you unscrew this slowly as it will drain any water in the washing machine so be carefull not to remove it quickly as you will get a lot of water everywhere when empty remove any grime or blockages from inside you can clear by hand then replace it back this should get rid of the key sign on the washing machine if the door still doesnt open near the filter should be aplastic peace on its own just looks like it doesnt do anything just pointing downwards if you pull that down it will release the door.
Apr 13, 2013 | Washing Machines
Hi, i have a bosch classixx5 washing machine(1400) , it's going through it's cycles until it tries to drain & then nothing, it won't drain... Please could you offer suggestions & s
You first of all need to check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and junk. The pump itself is directly behind the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is water in the washer, just some kind of precaution, so don't force the door.
Pl click if helped..
Mar 17, 2013 | Bosch Washing Machines
Hi I cant remove my filter cover located down on the bottom on front right. I have turned it anti clockwise and it wont come out to clean the filter. And suggestions please?
If you have unscrewed it all the way and it will not come out, then something is stuck in the filter preventing it from pulling out.
Screw it back in again, and then as you are unscrewing it, try moving it from side to side , it should eventually pull out, keep on doing this until it does come out.
If it does not, then you will probably have to remove the complete pump to clear the blockage.
Dec 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine was not draining. unscrewed filter at bottom of front of machine. All water drained out but filter still screwed in. is supposed to be attatched or is it clogged with hair and should i pull...
It should pul lall the way out, there is probably nsomething stuck in the filter, you will have to persist in trying to pull it all the way out, make sure it is fully unscrewed anti-clockwise.
Nov 29, 2010 | Washing Machines
Unable to unscrew cap on filter on washing machine
You should be unscrewing anti-clockwise to remove it, if it will not come out, then there is probably somethiung stuck in the filter preventing it from pulling out.
Try moving it from side to side as you are unscrewing and pulling.
Mar 17, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Unable to remove filter on machine
Assuming you have located the filter at the bottom front of washer, you unscrew it anti-clockwise to remove and clean.
If there is a small screw in the filter handle, then unscrew it first, before removing filter.
Thankyou.
Feb 01, 2010 | Candy AQUA1000T Front Load
My zanussi timeline 1600 washing machine has problems draining. Is there a way to fix this easily?
I suggest that you check and clean the filter.
This should be located at the bottom front right of washer behind drop down cover or flap. Unscrew anti-clockwise to remove and clean
Thankyou.
Jan 16, 2010 | Zanussi ZWF1650W Front Load Washer
Aquarius wf541. Am trying to unscrew and remove pump filter at front to clean and check for blockages as leaking water all over the floor.. Kick plate removed ok. turned filter anti clockwise as oer...
There must be something stuck in the filter, as normally it should pull straight out once you have unscrewed it.
Try screwing and unscrewing it at the same time keep twisting and pulling at the filter.
If you can't tremove it, then you sre going to have to remove the complete pump in order to clear the obstruction
Hope this helps you ..
Dec 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
UNABLE TO REMOVE FILTER ON ZANUSSI, EVEN THOUGH UNSCREWED
Having made sure you have unsrewed it all the way, then try pulling from side to side as you are unscrewing it, if you still can;t get it out, then something is stuck inside the filter, or the filter housing, this will entail removing the pump complete to clear blockage.
Thanks.
Oct 10, 2009 | Washing Machines
Bosch Maxx will not drain or spin. Cannot remove the filter cap located at front bottom right hand side to see if any blockage. Grrr....
Assuming you have tried to turn it anti-clockwise to remove filter, then something is probably stuck in filter, try pushing and pulling alternatively, and unscrewing at same time, if this does not work, then you are going to have to remove the complete pump with filter, and take it apart.
Thanks.
Aug 26, 2009 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
