May be your Network Admin/ISP blocked your messenger port....Please contact your network administrator.....if you use socks proxy please clear the proxy from network connection>Lan Setting>Unselect Use Proxy Server.......etc. or check the Connection Preferences in the messenger window and select Connect directly to the internet and save....All the best
SOURCE: login error 81003004 from Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection Prefrences and use a http proxy.
thank you
SOURCE: Login error 81003004 from Yahoo Messenger
It has already solved. Refer to :-
http://www.fixya.com/support/t1385966-login_error_81003004_from_yahoo
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
